  • Stefano Beretta 102 posts 247 karma points
    Mar 29, 2018 @ 12:46
    Stefano Beretta
    mainTreeEventHandler.syncTree is not a function
    Hi everyone!
    After the upgrade from 7.9.3 to 7.10.0 I get this error (attached image).
    It occurs if I reload (F5) a page, when the Url is set on a specific node (eg: /umbraco#/content/content/edit/9999). The error interrupts the others js, keeping the page in the "loading state".
    It seems Umbraco can't sync the tree on the current node selected by the url.
    Does someone have the same problem or it's just mine?
    Thank you!
    error
  • Søren Gregersen 441 posts 1884 karma points MVP 2x c-trib
    Mar 29, 2018 @ 13:16
    Søren Gregersen
    I’ve seen this too. On a clean 7.10 install
    Mar 29, 2018 @ 13:23
    Stefano Beretta
    I've downgraded to 7.9.3 and the error's gone.
    Re-upgraded to 7.10.0 and the error's back.
    Clean 7.10.0 install and the error is there (thanks Søren Gregersen).
    Should I report the issue?
    Thank you
    S
  • Michaël Vanbrabandt 863 posts 3348 karma points c-trib
    Apr 03, 2018 @ 08:36
    Michaël Vanbrabandt
    Hi Stefano,
    you can place this in the issue tracker: http://issues.umbraco.org
    Have a nice day.
    /Michaël
  • Mikael Syska 24 posts 91 karma points
    Apr 03, 2018 @ 08:34
    Mikael Syska
    Same issue here as you Stefano. Basically clean install with uSync.
    I would report it with the same description.
  • Andreas Emtinger 23 posts 185 karma points
    Apr 09, 2018 @ 09:32
    Andreas Emtinger
    Not fixed in 7.10.1. Did you report it?
    Apr 09, 2018 @ 09:41
    Michaël Vanbrabandt
    Hi all,
    issue is created on the tracker: http://issues.umbraco.org/issue/U4-11167
    Hope this helps!
    /Michaël
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Apr 09, 2018 @ 12:06
    Dave Woestenborghs
    And my fix has been merged in : https://github.com/umbraco/Umbraco-CMS/pull/2556
    Dave
    Apr 13, 2018 @ 07:09
    Dave Woestenborghs
    This is fixed in 7.9.4 and 7.10.2
    Dave
  • Giles Olley 9 posts 83 karma points
    Apr 13, 2018 @ 14:59
    Giles Olley
    We're still having this exact issue with 7.10.2 on multiple implementations. Just wondering if anyone else has found a fix I can manually add?
    Apr 13, 2018 @ 16:48
    Dave Woestenborghs
    Hi Giles,
    can you take the following steps.
    • Go to config/ClientDependency.config and bump the version number
    • Empty the cache of your browser
    • Try again
    Dave
  • Nicholas Westby 2054 posts 7104 karma points c-trib
    Apr 25, 2018 @ 22:07
    Nicholas Westby
    Hi Dave,
    Just tried on Umbraco 7.10.4. Content section seems fine. Formulate (a plugin that's not part of the Umbraco core) has the error, which is initiated from this line in the Formulate JavaScript:
    Does your fix apply to plugins as well, or is there some code change also required of plugins?
    Apr 26, 2018 @ 05:06
    Dave Woestenborghs
    Hi Nicholas,
    That is because you are calling the sync tree method directly in your code :
    https://github.com/rhythmagency/formulate/blob/master/src/formulate.app/JavaScript/Services/formulateTrees.js#L31
    And this can be null if the tree has not finished initializing yet.
    May you can handle it this way, by handling the promise that syncTree returns.
    https://github.com/dawoe/umbraco-tour-editor/blob/develop/Source/Our.Umbraco.TourEditor/Web/App_Plugins/TourEditor/scripts/controllers/edit-file-controller.js
    Dave
