  • nirmala 4 posts 74 karma points
    Mar 30, 2018 @ 11:04
    nirmala
    Route hijacking with custom controller & return url with custom parameter
    I'm having a little trouble in returning url with custom parameter (something that I've done a few times so probably missing something obvious).
    i'm trying to return product detail page from surface controller to umbraco template with url parameter.
    i had followed the methods below
    https://24days.in/umbraco-cms/2014/urlprovider-and-contentfinder/
    https://stackoverflow.com/questions/18201997/url-rewriting-in-asp-net-umbraco?rq=1
    https://stackoverflow.com/questions/46158391/making-custom-urls-in-umbraco-7-6-without-document-type
    but it's not working .i don't know what i'm missing
    Thanks in advance.
    Regards,
    Nirmala
    Apr 02, 2018 @ 07:57
    Alex Skrypnyk
    Hi Nirmala
    Can you show the code, please?
    Alex
    Apr 03, 2018 @ 04:54
    nirmala
    Hi alex,
    Here is my controller
    namespace UmbracoinmvcTrial.Controllers
        public class PropertySurfaceController : Umbraco.Web.Mvc.SurfaceController
            private MyContext db = new MyContext();//I'm using AnotherDB to return Data
            //Umbraco- PropertyDetail template
            public ActionResult PropertyDetailTemplate(int? PropertyID)
                Session["PropertyID"] = PropertyID;
                return View("PropertyDetail");
            //PropertyDetail-partialview
            public ActionResult propertyDetail(int PropertyID)
                PropertyDetailVM ProDatalList = new PropertyDetailVM();
                List<PropertyDataVM> prodetail = new List<PropertyDataVM>();
                //get propertydetail
                PropertyDetailRepo pd = new PropertyDetailRepo();
                prodetail = pd.Listdata(PropertyID);
                ProDatalList.PropertyDetails = prodetail;
                return PartialView("PropertyDetail", ProDatalList);
    my RenderMvcController
    using System;
    using System.Linq;
    using System.Web;
    using System.Web.Mvc;
    using Umbraco.Web.Models;
        public class PropertyDetailController : Umbraco.Web.Mvc.RenderMvcController
            // GET: PropertyDetail
            public ActionResult PropertyDetail(RenderModel model)
                //Do some stuff here, the return the base Index method
                return base.Index(model);
    my model
    using System;
    using System.Globalization;
    using System.Linq;
    using System.Web;
    using System.Web.Routing;
    using Umbraco.Core.Models;
    namespace UmbracoinmvcTrial.Models.VMModel
        public class PropertyDetail : RenderModel
            public PropertyDetail(IPublishedContent content) : base(content) { }
            string myparameter { get; set; }
            public IList<PropertyDataVM> PropertyDetails { get; set; }
    my startup.cs
    using System;
    using System.Linq;
    using System.Web;
    using Umbraco.Core;
    using Umbraco.Core.Events;
    using Umbraco.Core.Publishing;
    using Umbraco.Web;
    using Umbraco.Web.Routing;
    using UmbracoinmvcTrial.Controllers;
    using UmbracoinmvcTrial.Models;
    namespace UmbracoinmvcTrial.App_Start
        public class Startup : ApplicationEventHandler
            protected override void ApplicationStarting(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
                //With the url providers we can change node urls.
                UrlProviderResolver.Current.InsertTypeBefore<DefaultUrlProvider, PropertyDetailUrlProvider>();
                //With the content finder we can match nodes to urls.
                ContentFinderResolver.Current.InsertTypeBefore<ContentFinderByNotFoundHandlers, PropertyDetailContentFinder>();
        public class PropertyDetailUrlProvider : IUrlProvider
            public string GetUrl(Umbraco.Web.UmbracoContext umbracoContext, int id, Uri current, UrlProviderMode mode)
                var content = umbracoContext.ContentCache.GetById(id);
                if (content != null && content.DocumentTypeAlias == "PropertyDetail" && content.Parent != null)
                    var proid = HttpContext.Current.Session["PropertyID"].ToString();
                    var property = db.Properties.Find(proid);
                    var shortname = property.ShortName;
                    if (shortname != null)
                        //This will add the selected date before the node name.
                        //For example /propertydetail/ becomes /propertydetail/shortname/.
                        var url = content.Parent.Url;
                        if (!(url.EndsWith("/")))
                            url += "/";
                        return url + "/" + shortname + "/";
                return null;
            public IEnumerable<string> GetOtherUrls(Umbraco.Web.UmbracoContext umbracoContext, int id, Uri current)
                return Enumerable.Empty<string>();
        public class PropertyDetailContentFinder : IContentFinder
            public bool TryFindContent(PublishedContentRequest contentRequest)
                try
                    if (contentRequest != null)
                        //Get the current url.
                        var url = contentRequest.Uri.AbsoluteUri;
                        //Get the propertydetail nodes that are already cached.
                        var cachedproNodes = (Dictionary<string, ContentFinderItem>)HttpContext.Current.Cache["CachedPropertyDetailNodes"];
                        if (cachedproNodes != null)
                            //Check if the current url already has a propertydetail item.
                            if (cachedproNodes.ContainsKey(url))
                                //If the current url already has a node use that so the rest of the code doesn't need to run again.
                                var contentFinderItem = cachedproNodes[url];
                                contentRequest.PublishedContent = contentFinderItem.Content;
                                contentRequest.TrySetTemplate(contentFinderItem.Template);
                                return true;
                        //Split the url segments.
                        var path = contentRequest.Uri.GetAbsolutePathDecoded();
                        var parts = path.Split(new[] { '/' }, System.StringSplitOptions.RemoveEmptyEntries);
                        //The propertydetail items should contain 2 segments.
                        if (parts.Length == 2)
                            //Get all the root nodes.
                            var rootNodes = contentRequest.RoutingContext.UmbracoContext.ContentCache.GetAtRoot();
                            //Find the propertydetail item that matches the last segment in the url.
                            var proItem = rootNodes.DescendantsOrSelf("PropertyDetail").Where(x => x.UrlName == parts.Last()).FirstOrDefault();
                            if (proItem != null)
                                //Get the propertydetail item template.
                                var template = ApplicationContext.Current.Services.FileService.GetTemplate(proItem.TemplateId);
                                if (template != null)
                                    //Store the fields in the ContentFinderItem-object.
                                    var contentFinderItem = new ContentFinderItem()
                                        Template = template.Alias,
                                        Content = proItem
                                    //If the correct node is found display that node.
                                        //Add the new ContentFinderItem-object to the cache.
                                        cachedproNodes.Add(url, contentFinderItem);
                                    else
                                        //Create a new dictionary and store it in the cache.
                                        cachedproNodes = new Dictionary<string, ContentFinderItem>()
                                        HttpContext.Current.Cache.Add("cachedproNodes",
                                                cachedproNodes,
                                                null,
                                                DateTime.Now.AddDays(1),
                                                System.Web.Caching.Cache.NoSlidingExpiration,
                                                System.Web.Caching.CacheItemPriority.High,
                                                null);
                catch (Exception ex)
                    //Umbraco.LogException<PropertyDetailContentFinder>(ex);
                return contentRequest.PublishedContent != null;
            //ContentService.Published += Content_Published;
            private void Content_Published(IPublishingStrategy sender, PublishEventArgs<IContent> e)
                //Clear the content finder cache.
                HttpContext.Current.Cache.Remove("CachedPropertyDetailNodes");
    Regards
    Nirmala
