  • Robert 33 posts 173 karma points
    Apr 04, 2018 @ 10:56
    Robert
    Getting selected string value of dropdown using IContentService and IContent
    I am working in the backend of umbraco with the IContentService API and I need to read the dropdown selected string value of a combo.
    I have an IContent object representing the object I am working with. I have a dropdown called "Brand" and when I do:
    var brand = content.GetValue
    it does not return the selected string value visible in the UI, rather a number, in this case 231 and I don't what this refers to or how to get the selected string value.
  • Michaël Vanbrabandt 863 posts 3348 karma points c-trib
    Apr 04, 2018 @ 10:58
    Michaël Vanbrabandt
    Hi Robert,
    can you show us the complete code of where you want to access this Brand property?
    Also which version are you using of Umbraco?
    Thanks!
    /Michaël
    Apr 04, 2018 @ 11:00
    Robert
    The code is simply this:
    var brand = content.GetValue("Brand");
    //brand returns 231 but I need the selected string value of the combo
    Where content is the correct IContent object that I want to work with.
    Umbraco 7.
    Apr 04, 2018 @ 11:08
    Michaël Vanbrabandt
    Hi Robert,
    try this:
    var brand = content.GetValue<string>("Brand");
    Hope this helps!
    /Michaël
    Apr 04, 2018 @ 11:07
    Robert
    OK found the answer just need to use umbraco.GetPreValueAsString(231)
  • Nicholas Westby 2054 posts 7104 karma points c-trib
    May 22, 2019 @ 02:09
    Nicholas Westby
    Here's what I did on umbraco 7.14.0:
    /// <summary>
    /// Returns the value of a drop down property.
    /// </summary>
    /// <param name="page">
    /// The page with the drop down property.
    /// </param>
    /// <param name="propName">
    /// The name of the drop down property.
    /// </param>
    /// <returns>
    /// The drop down text value.
    /// </returns>
    private static string GetDropDownValue(IContent page, string propName)
        var dtService = ApplicationContext.Current.Services.DataTypeService;
        var valueId = page.GetValue<int?>(propName);
        if (!valueId.HasValue)
            return null;
        return dtService.GetPreValueAsString(valueId.Value);
    That's more just a note to myself in case I search for this again in the future.
