  • Mov3nforward 118 posts 320 karma points
    Apr 04, 2018 @ 22:54
    Mov3nforward
    Issue with Multi Url Picker and upgrade to 7.10.0
    I have an issue where something I have created in another site with version 7.6.6 that uses the Multi Url Picker plugin that does not seem to work in version 7.10.0. I setup a way for users to manage links for the main navigation of their web site. I am seeing an error when I try to view the front end and I am not sure why. I am using the exact same code and document type as I used in another site created with version 7.6.6.
    Can any one point me in the right direction?enter image description here
    Apr 04, 2018 @ 22:56
    Mov3nforward
    My partial code view.enter image description here
    Mov3nforward
    My doctypeenter image description here
    Apr 04, 2018 @ 22:57
    Mov3nforward
    How the doctype is used in the site.enter image description here
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Apr 05, 2018 @ 07:25
    Dave Woestenborghs
    Hi ,
    What version of Multi Url Picker are you using. Did you upgrade that as well ?
    Dave
  • Dan Diplo 1554 posts 6205 karma points MVP 6x c-trib
    Apr 05, 2018 @ 11:46
    Dan Diplo
    Are you using the version 2.x of Multi Url Picker? The way you access links changed in this version so you should do:
    var siteNavigation = mainNavigation.GetPropertyValue<IEnumerable<Link>>("navigation")
    https://github.com/rasmusjp/umbraco-multi-url-picker/blob/master/CHANGELOG.md#features-1
    Apr 05, 2018 @ 18:15
    Mov3nforward
    UPDATE: After hours of testing and going through each setting of the new site compared to the old site, I have finally gotten the old code that was written for version 7.6.6 and 7.8. The issue has to do with the Multi URL picker datatype. In the new site I had set the Min value to 0 and Max value to 100. In the 7.6.6 and 7.8 version sites, both values were set to blank. The code I have posted now works. I like using Umbraco, but upgrading it is a PIA compared to my WordPress sites. I wish the developers would only update every few months instead of a few times a month.
