First I would like to say I normally use Web Application projects when working with Umbraco; however, this particular project the client chose to use a Website project. This could be my lack of knowledge around how to make Umbraco work effectively in a Website project setting.
We are trying to build the solution (has 3 of projects: 1 - service layer project that also has ModelsBuilder models manually generated so we can use them in our service layer code, 2 - website project, 3 - service layer test project)
I’m getting this error when it’s trying to build in VSTS online (it builds locally just fine):
error ASPRUNTIME : The pre-application start initialization method Install on type Umbraco.ModelsBuilder.Umbraco.LiveModelsProviderModule threw an exception with the following error message: Could not load file or assembly ‘Umbraco.Core, Version=1.0.6597.38065, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. The system cannot find the file specified.. (edited)
Also here are my web.config settings for the ModelsBuilder (because I’m compiling them via the VS plugin and Api layer) in another Services project to be used in my code:
@Paul, just a thought, you have installed Umbraco.Core (the same version as the main website project) into your project that Models Builder is installing into? (And any extensions such as Stacked Content, Cogworks Mega nav etc) ?
VSTS Online Build Issue - Umbraco Website Project
I’m getting this error when it’s trying to build in VSTS online (it builds locally just fine): error ASPRUNTIME : The pre-application start initialization method Install on type Umbraco.ModelsBuilder.Umbraco.LiveModelsProviderModule threw an exception with the following error message: Could not load file or assembly ‘Umbraco.Core, Version=1.0.6597.38065, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. The system cannot find the file specified.. (edited)
I'm currently experiencing the same problem, did you manage to find a solution for this?
