  • Sean Håkansson 68 posts 204 karma points
    Apr 09, 2018 @ 11:34
    Sean Håkansson
    (RJP)Multi Url Picker Media reference
    How does (RJP) Multi URL picker save picked media files? Does it story node reference or does it store current URL?
    We have a client who links to media that gets updated annually, do they have to update all picker reference on the site, or can they keep updating existing media?
  • Michaël Vanbrabandt 863 posts 3348 karma points c-trib
    Apr 09, 2018 @ 11:43
    Michaël Vanbrabandt
    Hi Sean,
    it stores the identifier to the Media object. So when you update the existing Media node with a new image or video or whatever, you don't have to update all your pickers in the content section.
    As you can see above we have a media item which is used in media pickers. Then below the image you can choose to remove this image and pick a new one. After you saved this media item, this new image will be displayed on your frontend on all places where you referenced this media item.
    Hope this helps.
    /Michaël
    Apr 09, 2018 @ 21:45
    Sean Håkansson
    Excellent, thanks! Was this always the case? I remember we had an issue before, where it would store the URL as an external URL.
    Apr 10, 2018 @ 07:51
    Michaël Vanbrabandt
    Hi Sean,
    in my experience it was always like this but could be that it had issues in the past.
    Have a nice day!
    /Michaël
