If you are using the latest version of the Multi Url Picker package, so shouldn't use MultiUrls since it is deprecated.
Instead cast the value IEnumerable<Link> or Link if you have set maximum = 1 in the property editor config.
var categories = Model.Content.GetPropertyValue<IEnumerable<Link>>("categoryLinks");
var category = Model.Content.GetPropertyValue<Link>("categoryLink");
if you are using ModelsBuilder you can just write:
Multi URL picker help
Hi Guys,
Just started using umbraco and i can't seem to get this package to work. I'm not using the model viewer for my site.
How can you access the values you've stored?
Here is a sample code i created
I am getting a parsing error for this
Can anyone point me in the right direction?
Hi John
Are you using this package - https://our.umbraco.org/projects/backoffice-extensions/multi-url-picker/ ?
All files are in place?
What error did you get?
/Alex
Yes thats the package I'm using. I am getting a parsing error when I'm adding the get property value for multi urls.
All files are in place in the App_Plugins.
Add please:
@using RJP.MultiUrlPicker.Models
And what parsing error did you get?
Can you check what is storing in "categoryLinks" Umbraco field?
Hi Alex,
Thanks for the reply, have found another way to get what I want. This will do for now as I am really pressed for time.
Really appreciate the reply.
You are welcome, John.
Aks if you have a question, have a nice day!
Hi John
MultiUrlssince it is deprecated.Instead cast the value
IEnumerable<Link>orLinkif you have set maximum = 1 in the property editor config.if you are using ModelsBuilder you can just write:
or
/Bjarne
