  • Alen Kule 3 posts 74 karma points
    Apr 17, 2018 @ 08:51
    Alen Kule
    Translation problem
    Hello, can some1 help me figure out how or why this didn't translate (picture below),
    Thx.
  • Michaël Vanbrabandt 863 posts 3348 karma points c-trib
    Apr 17, 2018 @ 09:20
    Michaël Vanbrabandt
    Hi Alen,
    Welcome to the Umbraco community forum!
    Could you tell me which language you use? Then I can check the language files to see if this key isn't present in the file.
    Also, could you translate it for me then I will make a Pull Request for this so that it gets merged into the next release.
    Thanks!
    /Michaël
    Apr 17, 2018 @ 09:33
    Alen Kule
    I am using Bosnian language (made a copy of the English lang file and translated it), the translation would be:
    "Objavi" "Spašavanje i objava izvedena od strane korisnika"
    Apr 17, 2018 @ 09:51
    Michaël Vanbrabandt
    Hi Alen,
    seems like there is no language file specifiied for your language.
    Can you specify the language code for your language? Also do you have a github account? Then you can do a PR with the translations for your language.
    Link to the correct folder and branch which you need to add your language file:
    https://github.com/umbraco/Umbraco-CMS/tree/dev-v7/src/Umbraco.Web.UI/umbraco/config/lang
    Hope this helps!
    /Michaël
    Apr 19, 2018 @ 08:27
    Michaël Vanbrabandt
    Hi Alen,
    any news on this? Di you managed to upload the translation file onto the github repo of Umbraco Cms?
    Thanks!
    /Michaël
    Apr 19, 2018 @ 09:14
    Alen Kule
    Hi Michael, no, apparently this message is pulled from the database and the "Publish" is triggered from javascript, so another colleague will look into it.
    Thx for the fast replays and after we fix the issue i'll post it here. :)
