  • Paul 184 posts 646 karma points
    Apr 19, 2018 @ 14:14
    Paul
    Unable to change users password using MS Edge (Umb 7.10.3 & 7.10.4)
    Hi all,
    I've just upgraded a couple of sites to 7.10.3, but I've noticed that when I try to change a user (not a member) password in Edge it highlights the Email field and says required. Obviously this is already populated. The password change function works as expected in Chrome.
    Any ideas on how to fix it?
    Thanks!
  • Michaël Vanbrabandt 863 posts 3348 karma points c-trib
    Apr 19, 2018 @ 14:56
    Michaël Vanbrabandt
    Hi Paul,
    any console errors in MS Edge?
    Thanks!
    /Michaël
    Apr 23, 2018 @ 08:20
    Michaël Vanbrabandt
    Hi Paul,
    any news on this? Can you share it with the community?
    Thanks!
    /Michaël
    May 18, 2018 @ 15:07
    Paul
    Upgraded to 7.10.4, getting the same issue. Not sure why, there's nothing logged in the console.
    Process: Users > Click on a user > Change Password > Complete the Password Field (so it matches) > Hit Save and that's when the Email field is highlighted in red with "Required" below it.
    Ideas on a postcard please folks!
    *Works fine in Chrome, obviously....
    Aug 13, 2018 @ 09:45
    Paul
    Update to this one. I'm still getting this issue in Edge on a variety of 7.10.4 sites. I'm guessing it's a bug?
    The current workaround I'm using is as follows:
    Delete last char from email field, then re-add it immediately, now press save and the users details are saved correctly.
    Apr 04, 2019 @ 14:35
    Paul
    Upgraded to 7.13.2 issue gone.
