I am still struggling a little extending my unit testing to include code with Umbraco Dependencies. I got past my last problem but now have another. I am using the "UmbracoSupport" Class which uses Our.Umbraco.Community.Tests and then executing the following code to obtain an UmbracoMember object so I can read and write custom Member properties. The problem is that I end up with a null UmbracoMember object which means I can not test correctly.
public UPSCalculateShippingReturn UPSCalculateShippingRequest(Shipment shipment, string memberUserName)
UPSCalculateShippingReturn uPSCalculateShippingReturn = new UPSCalculateShippingReturn();
Umbraco.Core.Services.IMemberService memberService = null;
memberService = ApplicationContext.Current.Services.MemberService;
var umbracoMember = memberService.GetByUsername(memberUserName); // <<<<<<<<<<< Does not work – returns Null
// ………………………… More unrelated code
Using the debugger it seems that the MemberService is "Mocked" which probably explains why it is returning null. Is there a way to get a "real MemberService to access and test against the real members in the database ?
FYI I am using
Umbraco version 7.5.10 (assembly: 1.0.6261.14290)
UCommerce uCommerce 7.5.0.17040
NUnit {3.10.1}
NUnit3TestAdapter {3.10.0}
Moq {4.1.1309.0919}
Our.Umbraco.Community.Tests Nuget package (Version
7.5.10 to match my installed version of Umbraco.)
Unit Tests which use MemberService
Updating question due to progress......
Hi all,
FYI I am using
http://blog.aabech.no/archive/the-basics-of-unit-testing-umbraco-just-got-simpler (after the heading "THE IMPLEMENTATION")
Any assistance to overcome this problem would be appreciated !
Terry Clancy
ClanceZ
