Fresh installation (7.10)
http://{url}/umbraco/backoffice/UmbracoApi/DataType/PostSave
{"Message":"The request is invalid.","ModelState":{"Properties.items.item0":["The value #2bac3a is not a valid hex color"],"Properties.items.item1":["The value #212d22 is not a valid hex color"]}}
Anyone with the same problem?
Thx
Hi Olivier,
have a look at this thread on the issue tracker:
http://issues.umbraco.org/issue/U4-11257
Is a problem with the Chrome 66
Hope this helps!
/Michaël
Michaël,
You 're right! Thx! IE works
Olivier
Olivier,
no problem!
Enjoy the rest of the day!
don't forget to mark the answer which solved your problem ( icon on the right bottom of the post you want to set as the answer ).
Thanks!
https://umbraco.com/blog/chrome-66-causing-errors-on-some-umbraco-sites/
thanks for sharing the blog post!
Upload image
Error when saving "Color Picker"
Thx
Hi Olivier,
Hope this helps!
/Michaël
Michaël,
Olivier
Olivier,
no problem!
/Michaël
Olivier,
Thanks!
/Michaël
Olivier,
/Michaël
