  • Yajamanam 36 posts 106 karma points
    Apr 24, 2018 @ 15:47
    Yajamanam
    Deployment using Umbraco courier with octopus Integration
    Hi ,
    i am using umbraco courier tool for deploying umbraco related things in staging site. I want to atomize this courier sync in Octopus tool,as i have deployed all the files as well as content in one single place. can anybody suggest me how to integrate/configure courier in octopus.
    please let me know the configuration setup needed on this.
    Thanks. Pradeep.
  • Søren Gregersen 441 posts 1884 karma points MVP 2x c-trib
    Apr 24, 2018 @ 22:03
    Søren Gregersen
    You need to start the site, and run some code inside a startup-event.
    There should be some method in courier where you can import the files.
    Other options would be to use stuff like uSync or maybe Chauffeur. The latter is build for this kind of development
