  • Christina 127 posts 390 karma points notactivated
    Apr 25, 2018 @ 14:45
    Christina
    duplicated pages in meny with same page id
    Hi have started with umbraco and have a problem My mainmenu shows a page 2times with the same pageid.
                            var selection = Model.Content.Site().Children()
                                                .Where(x => x.IsVisible());
                        <ul>
                            @foreach(var item in selection){
                                <li>
                                    <a href="@item.Url">@item.Name @item.Id</a>
                                </li>
                        </ul>
    Can someone help me and explain whats wrong
  • Nigel Wilson 945 posts 2077 karma points
    Apr 25, 2018 @ 19:12
    Nigel Wilson
    Hi Christina
    The above snippet looks fine based on what you have provided.
    Is this code in your main template, or is it in a separate partial view and you are calling the partial from a template ?
    If separate can you also provide the template code ?
    Cheers
    Nigel
    Apr 25, 2018 @ 19:36
    Christina
    Hi Nigel Thanks i have the code in masterpage. I have a root node and the pages under. I printed out the pageId and it's the same for two of the children pages
    Apr 25, 2018 @ 19:48
    Nigel Wilson
    Hi Christina
    Can you post the code for your masterpage template please - sorry, should have asked before... :-)
    Nigel
    Apr 26, 2018 @ 05:53
    Christina
    Hi again thanks i deleted the page that was showed tvice. /Christina
