  • Mila Pandurska 43 posts 190 karma points
    May 03, 2018 @ 05:00
    Mila Pandurska
    Get Culture from IContent in ContentService_Published method
    Hi, I have a multilingual website and I use ContentService_Published method to do some custom logic when I publish a node - I need to do
    ExamineManager.Instance.IndexProviderCollection["IndexPrivider"].ReIndexNode(child.ToXml(applicationContext.Services.PackagingService), "content");
    I have different searchIndexes for the different languages so I need to know which index to ReIndex. The code that I have so far is:
     public void ContentService_Published(IPublishingStrategy sender, PublishEventArgs<IContent> e)
            var culture = System.Threading.Thread.CurrentThread.CurrentUICulture.Name;
            foreach (var content in e.PublishedEntities)
                if (content.ContentType.Alias == "node")
                    foreach (var child in content.Descendants().Where(c => c.ContentType.Alias == "subNode"))
                        ExamineManager.Instance.IndexProviderCollection[GetIndexer(culture)].ReIndexNode(child.ToXml(applicationContext.Services.PackagingService), "content");
    The method GetIndexer() check the culture and returns the respective value. The problem is that var culture = System.Threading.Thread.CurrentThread.CurrentUICulture.Name; is always "en-US" which is (I guess) the culture of the logged in in Umbraco user. Is there a way to get the culture of the item that I am publishing?
    Mila
  • kows 81 posts 151 karma points c-trib
    May 07, 2018 @ 13:39
    kows
    You could get the node from cache & get the culture from there.
    var node = UmbracoContext.Current.ContentCache.GetById(content.Id);
    var culture = node.GetCulture();
  • Sotiris Filippidis 286 posts 1501 karma points
    Jun 15, 2019 @ 23:12
    Sotiris Filippidis
    Isn't there any way to get the culture from the IContent object instead? I mean, when publishing you can only publish one culture so shouldn't the IContent object contain this information? (Asking because I haven't managed to find it yet :) )
  • Rihab 104 posts 388 karma points
    Jul 31, 2019 @ 11:36
    Rihab
    Hi, Searching for the same thing..... any luck? thanks. Rihab.
  • Rosen Petrov 8 posts 28 karma points
    Apr 22, 2021 @ 11:34
    Rosen Petrov
    Searching for the same thing.. :D Anybody?
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Aug 01, 2024 @ 07:52
    Steve Morgan
    An old thread but the answer is that culture info can be found in IContent under
    .PublishCultureInfos
