  • Aniello 2 posts 72 karma points
    May 03, 2018 @ 07:40
    Aniello
    Resolution is not frozen, it is not yet possible to get values from it.
    Hi everyone. I just publish my new website but when i try to connect to it, the browser shows me this error
    I attach to this post a screenshot of the error. Could be the error caused by different .net framework version between Umbraco and the IIS?
    Thanks and sorry for my english!
  • Michaël Vanbrabandt 863 posts 3348 karma points c-trib
    May 03, 2018 @ 14:44
    Michaël Vanbrabandt
    Hi Aniello,
    which version are you using of Umbraco? I can see that this error has been seen before but in version 6.x.
    http://issues.umbraco.org/issue/U4-2174
    Hope this helps!
    /Michaël
    May 03, 2018 @ 14:45
    May 03, 2018 @ 18:45
    Aniello
    Hi Michaël, thanks for your answers. I'm using Umbraco 7.8.1. The problem seemed to be solved when i removed and reuploaded the Global.asax file. But after a while the error came back. I read the links you posted but i can't find a solution.
  • Damien Holley 181 posts 542 karma points
    Feb 19, 2019 @ 06:02
    Damien Holley
    I got this error just now, stepped through the program and discovered the source error causing this was a duplicate model issue.
    I had included the models from App_Data/ Models to use strongly typed models in my backend code, this was conflicting with the Umbraco.Web.PublishedContentModels.dll file in my bin folder.
    I removed the models folder and put in a reference to the DLL and it worked fine.
