I've spent far to long looking for an answer to this now.
I have a working pagination which reloads the page, and appends ?page onto the url, however i would like to convert this over to use ajax for pagination.
There seems to be no information on how to achieve this with Umbraco 7 anywhere, so a little help would be greatly appreciated.
I have an array of images which i am showing 5 per page currently.
I have used the pagination available on this form to create a pagination.
But because i'm using this for a gallery it doesn't work in the best user friendly way.
I'm pretty new to AJAX and so i do not know where to start with converting this over, there is very little in terms of documentation and examples to see how to achieve this really simple idea
Hi Aaron, this isn't really related to Umbraco as much as AJAX but you can take a look at this infinite scroll plugin we use for our blogs, long lists etc: https://github.com/pklauzinski/jscroll
AJAX pagination with Umbraco... How to?
Thanks!
Hi Aaron,
It would be great if you could tell us more about the data that your are trying to paginate.
Hope this helps,
Amir
