  • Christina 127 posts 390 karma points notactivated
    May 29, 2018 @ 08:36
    Christina
    Help with querystring
    Hi i need some help I have implemeted the search from https://codeshare.co.uk/blog/how-to-search-by-document-type-and-property-in-umbraco/
    I want to pass the to the /search?query=something take and the query value from the Request.QueryString and pass it to the RenderForm action.
    Can someone help me Thanks in advance Christina
  • Paul Seal 524 posts 2890 karma points MVP 8x c-trib
    May 29, 2018 @ 10:47
    Paul Seal
    2
    Hi Christina
    In the view you can add something like this
        string searchTerm = Request.QueryString["query"];
    Then when you call the render action you can pass it in like this
    @{ Html.RenderAction("RenderSearchForm", "Search", new { searchTerm =  searchTerm }); }
    And in the action you can pick up the value in the constructor like this
    [HttpGet]
    public ActionResult RenderSearchForm(string searchTerm)
        //code in here
    I hope that helps.
    Paul
    May 29, 2018 @ 11:10
    Paul Seal
    Although just having query in the Action should work without the rest of it.
    [HttpGet]
    public ActionResult RenderSearchForm(string query)
        //code in here
    May 29, 2018 @ 11:17
    Christina
    Hi Paul Many thanks I really appreciate your videos. Another question If i want the searchform in the header what should i do /Christina
    May 29, 2018 @ 13:42
    Paul Seal
    101
    You're welcome.
    You could just add a simple form like this in the header.
    <form action="/search/" method="GET">
        <input type="text" placeholder="Search..." name="query">
        <button>Search</button>
    </form>
    Kind regards
    Paul
    May 29, 2018 @ 14:36
    Christina
    Many Thanks
