  • Nadine Fisch 159 posts 429 karma points
    Jun 04, 2018 @ 06:11
    Nadine Fisch
    Ajax Call: Wrong Url Path
    I try to call a Controller Method via Ajax, but I am not able to use the correct path. Can anyone help me, please?
    The Method is in App_Code\Controllers\API\ExampleController.cs
    And in my Example.cs-file I have following code
    [AcceptVerbs("GET", "POST")]
             [HttpPost]
             [Route("/example/add/")]
             public String addExample(){
                    return "success";
    My Ajax-Call:
    $.ajax({
        type: "POST",
        url: "/Controllers/API/example/add/",
        success: function (result) {
            alert(result);
        error: function (result) {
            console.log(result);
    Thank you, Nadine
    Jun 04, 2018 @ 06:46
    Nadine Fisch
    101
    This solution works for me:
        url: "/Umbraco/Api/Example/addExample"
    Apparently, if I inherit from "UmbracoApiController" the Path always starts with /Umbraco/Api/
    /Umbraco/Api/{Controller}/{method}
    Jun 04, 2018 @ 07:03
    Hi Nadine
    Happy to see you found the solution - This is also mentioned in the documentation here https://our.umbraco.org/documentation/Reference/Routing/WebApi/ if others should come across this post with the same issue as you.
    Have a nice day :-)
