  • Dustin 10 posts 78 karma points
    Jun 08, 2018 @ 21:48
    Dustin
    Alternative to Multi-Node-Treepicker control.
    Hello all!
    My company is still using the Multi-Node-Treepicker control with Umbraco v 7.4.1.3. Documentation says this is deprecated.
    Question: Should we even still be using this control, and if not, what do you think the appropriate alternative should be?
    Thanks! Dustin
    Jun 08, 2018 @ 22:20
    Hi Dustin
    It's not deprecated - But there has been an update to it. And quickly looking at the list of built in property editors here https://our.umbraco.org/documentation/Getting-Started/Backoffice/Property-Editors/Built-in-Property-Editors/ can give one that idea.
    However there is 2 listed...The old one that has been marked as obsolete with the release of v7.6, which is the one documented here https://our.umbraco.org/documentation/Getting-Started/Backoffice/Property-Editors/Built-in-Property-Editors/Multinode-Treepicker
    And then the "new" one, which is still very alive and kicking here https://our.umbraco.org/documentation/Getting-Started/Backoffice/Property-Editors/Built-in-Property-Editors/Multinode-Treepicker2
    The difference is how the selected values are returned. The old picker returned either an id or a csv list of values. The new one returns a IEnumerable
    So by all means keep using the multinode treepicker on your solutions.
