  • Joshua McBride 5 posts 85 karma points
    Jun 09, 2018 @ 17:06
    Joshua McBride
    Checkbox True False If Statement
    I am new to working with Umbraco.
    I have a checkbox inside a document type.
    The field is called Hero Image Filter and it's intended purpose will allow the user to add a preset filter to the hero image, or remove it.
    The checkbox is selected, and returns a value of True when the following command is placed inside the template
    @Umbraco.Field("homeheroImageFilter")
    When I create a variable as follows, it still returns the correct value
    @{var filter = Umbraco.Field("homeheroImageFilter");}
    @filter
    Now I want to use the variable to create an if statement, where if the condition is true it shows a
    tag and content.
    This returns a compilation error
    @filter
    @if(filter == "True"){<p>Test</p>}
    This also returns a compilation error
    @filter
    @if(@filter == "True"){<p>Test</p>}
    But when I change the if condition as follows, it works as expected..
    @if("True" == "True"){<p>Test</p>}
    So, what am I doing wrong? All help would be appreciated!
    Jun 09, 2018 @ 17:23
    Dennis Aaen
    Hi Joshua, and welcome to Umbraco :)
    Have a look here how to work with the true / false
    https://our.umbraco.org/documentation/getting-started/backoffice/property-editors/built-in-property-editors/True-False
    Hope this helps,
    /Dennis
    Jun 09, 2018 @ 17:30
    Joshua McBride
    Hi Dennis,
    Thanks for the link, but can you help me modify this code to display the value I need returning?
    J
    Jun 09, 2018 @ 18:02
    Hi Joshua and also welcome to the Our forum :)
    You need to change this
              <p>Test</p>
    Into this and then it should work for you
        @if(filter.ToString() == "True"){
            <p>Test</p>
    Here you make sture to convert whatever the type of value you get back in your variable to a string and therefore you are now comparing two strings and won't see the yellow screen of death.
    I hope this makes sense?
    Jun 09, 2018 @ 18:10
    Dennis Aaen
    Hi Joshua,
    Here is a piece of code that you can use. So if the checkbox is checked then you will get the value printed out.
    @if (Model.Content.GetPropertyValue<bool>("homeheroImageFilter")){
                <p>@Model.Content.Name</p>
    A little explanation. Model.Content is refer to the page that you are viewing in the browser. Its the same when you are using the
    So make sure that the page that you are viewing in the browser has the property on the page. Else you will need to do some traversing.
    Hope this helps,
    /Dennis
    Jun 10, 2018 @ 09:33
    Joshua McBride
    Thanks guys!
