  • Lewis Smith 211 posts 620 karma points c-trib
    Jun 18, 2018 @ 08:27
    Lewis Smith
    On page load
    Hi all,
    I'm looking to hit a method on page load for certain document types. This will allow me to check if the page (retail page) has products before the page has loaded. If not I can update the page status which should help to rank the page with Google.
    I know there is the ApplicationEventHandler which has ApplicationStarted, is there anything that I can override so it triggers on the start of page load so i can get in there to update the status before its too late?
    Thanks, Lewis
    Jun 18, 2018 @ 09:06
    Dave Woestenborghs
    Hi Lewis,
    What status do you want to return ?
    Dave
  • Alex Brown 129 posts 620 karma points
    Jun 18, 2018 @ 09:13
    Alex Brown
    I'd consider a RenderMvcController.
    The name of your controller must match your document typename, and the method name must match the template name. E.g. below, I have a document type called "Product" and a template attached to it called "Product".
    public class ProductController : RenderMvcController
        public ActionResult Product(IPublishedContent content)
    Jun 18, 2018 @ 10:11
    Lewis Smith
    Hi Alex,
    This is the solution im trying to avoid. We have multiple different document types for products and this would need this check on each one. I could create a link to a helper controller which could do the same but im trying to future proof the site so we can extend the if needed. A page load method would work better but if not this is the route I will go down.
    thanks, Lewis
