I am using Umbraco cloud and have created a drop down menu to select the state (NSW, VIC etc) in the members section and I am using a partial view.
When the state is selected it displays a value and not the text (NSW)
@foreach (var member in ApplicationContext.Current.Services.MemberService.GetMembersByMemberType("activeMembers"))
var prac1st = member.GetValue<string>("practice1State");
<p> @prac1st </p>}
If the dropdown list is made from prevalues as shown in the screenshot below you'll need to do some extra lookups in the code.
var memberStateDataType = Umbraco.DataTypeService.GetDataTypeDefinitionByName("Member State - Dropdown list");
var memberStateDictionary = Umbraco.DataTypeService.GetPreValuesCollectionByDataTypeId(memberStateDataType.Id).PreValuesAsDictionary;
var stateProperty = member.Properties.FirstOrDefault(p => p.PropertyType.Alias == "practice1State");
var selectedPreValueId = int.Parse((string)stateProperty.Value);
var selectedPreValue = memberStateDictionary.FirstOrDefault(preValue => preValue.Value.Id == selectedPreValueId);
// next line is the state e.g. "NSW"
var selectedState = selectedPreValue.Value.Value;
It's not very elegant but if you're doing it in Razor I think this is what you have to do. If anyone else can provide something better I'd love to know.
Im dealing with the issue to render SELECTED VALUE to html .
@if (Model.HasValue("productcategory"))
var memberStateDataType = Umbraco.DataTypeService.GetDataTypeDefinitionByName("productcategory- Dropdown");
<p>@selectedState</p>
Drop down menu returning number not string
How do I display the value NSW, VIC etc
Hello Jf
Do you have a way how to render it simply ?
Thank you.
Thanks jf
