Is there a way or workaround to move the Dictionary out of the Settings panel so that the Editor (or another user group) can only update dictionary items and not play around with document types and templates?
or
A way to hide other items in Settings panel for the Editor, so that she can only see and edit the dictionary node?
moving the dictionary tree for example to the translation sections works fine. But since 7.12.* the dictionary tree is not visible in the translation section if a user does not have permission to the settings section where the dictionary tree takes originally place. Can you have a look on this issue?
Move Dictionary out of Settings section
or
Best regards.
Hi Thomsen,
I believe that this is now possible on the latest version of Umbraco (7.11.*). But prior to this, no it wasn't possible.
Nik
Hi Nik
Mary
Yup, Nik is right - Possible in the 7.11 (SevenEleven, hihi) release and mentioned in the blogpost about the release here https://umbraco.com/blog/umbraco-version-711-release/
Thanks to both of you - time for an upgrade :-)
Have a nice day!
Just an update for 7.11.1: you can now put it in any section you want!
So the default is:
Change
application="settings"toapplication="translation"orapplication="content"orapplication="media"(don't.. but it should work haha).In 7.11.0 it's a bit more limited, but 7.11.1 is amazing :-)
I've also written a package specifically to make it simple for Editors to manage the dictionary entries you can use:
https://our.umbraco.com/projects/backoffice-extensions/diplo-dictionary-editor/
Hi, I've installed your plugin (Diplo-Dictionary) but cannot find it on any sections Do you have any suggestions?
Apparently, It has shown up after some build @@
It doesn't seem to work for us with the amount of items we have in the dictionary... :( We have around 60 languages atm...
