Can you provide a bit more information about your setup? Have you configured the 404 pages in the /config/umbracoSettings.config file - If so can you please share what your configuration looks like? If not can you then please tell us how you're serving up the 404 pages instead?
And did you just upgrade an existing site from a previous version of Umbraco and started seeing this happen? Or is it something you have noticed on a fresh installation?
Ok I see that you have updated the initial post and also added the configuration setting in an additional post - I took the liberty to cut the second post down to only show the <errors> section, so we don't need to scroll through the entire file :)
When you say it does not work in 7.7 - Does that mean that these settings has previously worked for you? I'm trying to figure out if this has stopped working after en upgrade or if you have been running v7.7 for a while?
How have you setup the french and spanish sites? Do they have a hostname setup on the homepage root node? If not then that might be the reason why you get the english error 404 page.
Display 404 error page as per culture not working
Display 404 error page as per culture not working in Umbraco 7.7
French 404 Error Page Redirected to English 404 Error Page
Hello
Looking forward to hearing from you.
This is My umbracoSettings.config file
French and Spanish 404 Error Page redirected to English 404 Error Page
Hello again
<errors>
section, so we don't need to scroll through the entire file :)When you say it does not work in 7.7 - Does that mean that these settings has previously worked for you? I'm trying to figure out if this has stopped working after en upgrade or if you have been running v7.7 for a while?
