  • Riaz 5 posts 75 karma points
    Jul 08, 2018 @ 05:55
    Riaz
    Site not working even after configuring trust level to full
    Please check the image, i do still get this error even after configuring the trust level to "full". Kindly support.
  • Owain Williams 482 posts 1414 karma points MVP 7x c-trib
    Jul 08, 2018 @ 20:10
    Owain Williams
    Hi Riaz,
    This looks like you are running Umbraco Forms, what version are you using?
    By any chance, have you had Umbraco Contour installed at some point and now trying to use Umbraco Forms?
    O.
    Jul 09, 2018 @ 06:24
    Riaz
    Thank you Owain,
    I am using UmbracoForms.Package.4.4.4 .
    I never installed Contour , from the beginning we are using only umbraco forms.
    I developed the website in local development environment using visual studio code and then i just moved all the content to the godaddy shared hosting server which has plesk control panel and still i am trying to use the SQL CE. is that ok ?
    Jul 09, 2018 @ 07:19
    Owain Williams
    It seems to be a common issue with GoDaddy from what I can find when searching websites. If I find anything that might help, I'll drop a message here.
    Maybe worth dropping GoDaddy support an email?
    O.
