  • Mark Watson 118 posts 384 karma points
    Jul 12, 2018 @ 07:38
    Mark Watson
    Running uaas-cmd on mac
    I am following the documentation here https://our.umbraco.com/documentation/Umbraco-Cloud/Set-Up/Visual-Studio/ and am trying to create my visual studio solution for my cloned site. Anyone know how I run the uass_cmd or does this not work for mac?
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Jul 12, 2018 @ 07:52
    Nik
    Hi Mark,
    I don't believe that that will work for mac. Are you trying to use Visual Studio for Mac so you can write compiled code for Umbraco? I ask because I'm not certain that this is possible. (I may well be wrong).
    I believe that VS for Mac can't do full .Net (https://docs.microsoft.com/en-us/visualstudio/mac/) it is limited to .Net Core (which Umbraco isn't built on) and Xamrin style projects.
    Nik
    Jul 12, 2018 @ 08:18
    2
    Hi Mark
    Just want to add a little more information to what Nik explained above it's not possible to run Umbraco locally on a mac. You will need to either use Bootcamp or run some kind of virtual machine, which will allow you to setup Windows where you can then run visual studio - It's described here https://our.umbraco.com/documentation/getting-started/setup/install/running-umbraco-on-a-mac
    When using Umbraco Cloud you can use the UAAS-Cli as described here https://our.umbraco.com/documentation/Umbraco-Cloud/Set-Up/Working-with-UaaS-Cli/, which will allow you to edit your frontend files locally. So stuff like JavaScript, CSS and Views for instance.
    But that's about it for now :-)
    Hope this helps.
    Jul 13, 2018 @ 00:23
    Mark Watson
    Thanks Jan
