  • Stelios Giannoulis 4 posts 84 karma points
    Jul 17, 2018 @ 10:52
    Stelios Giannoulis
    Umbraco 4.x multi site setup and redirection from http to https
    we have an umbraco 4.x multi site setup on a windows 7.x server. We recently installed an ssl certificate for all the domains so we want to redirect from http -that they are currently- to https.
    As I am very new to umbraco; if we put this rule in web.config would it do the trick?
    <rule name="HTTP to HTTPS redirect" stopProcessing="true">
      <match url="(.*)" />
      <conditions>
       <add input="{HTTPS}" pattern="off" ignoreCase="true" />
       <add input="{HTTP_HOST}" pattern="localhost" negate="true" />
      </conditions>
      <action type="Redirect" url="https://{HTTP_HOST}/{R:1}" redirectType="Permanent" />
     </rule>
    Thank you very much in advance for your help.
  • Jamie Townsend 62 posts 287 karma points c-trib
    Jul 17, 2018 @ 12:18
    Jamie Townsend
    That looks pretty much exactly what I've used myself on a few projects and it's always worked fine.
    Give it a shot!
    Jul 17, 2018 @ 12:42
    Stelios Giannoulis
    Ha!
    It worked!!
    My first umbraco code update!
    My main concern was the multi site setup.
