I just openen my umbraco solution on my other machine and got this error on all my views. It's running on the same DB ?
Umbraco.Web.Mvc.ModelBindingException: Cannot bind source content type Our.Umbraco.DocTypeGridEditor.Models.DetachedPublishedContent to model type Umbraco.Web.PublishedContentModels.ImageQuotePicker.
ved Umbraco.Web.Mvc.RenderModelBinder.ThrowModelBindingException(Boolean sourceContent, Boolean modelContent, Type sourceType, Type modelType)
ved Umbraco.Web.Mvc.RenderModelBinder.BindModel(Object source, Type modelType, CultureInfo culture)
ved Umbraco.Web.Mvc.UmbracoViewPage`1.SetViewData(ViewDataDictionary viewData)
ved System.Web.Mvc.RazorView.RenderView(ViewContext viewContext, TextWriter writer, Object instance)
ved Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer)
ved System.Web.Mvc.Html.PartialExtensions.Partial(HtmlHelper htmlHelper, String partialViewName, Object model, ViewDataDictionary viewData)
ved Our.Umbraco.DocTypeGridEditor.Web.Extensions.HtmlHelperExtensions.RenderDocTypeGridEditorItem(HtmlHelper helper, IPublishedContent content, String editorAlias, String viewPath, String previewViewPath)
ved ASP._Page_app_plugins_doctypegrideditor_render_doctypegrideditor_cshtml.Execute() i c:\Development\cabana.koda_sitegen\cabana.koda_sitegen\App_Plugins\DocTypeGridEditor\Render\DocTypeGridEditor.cshtml:linje 28
ved System.Web.WebPages.WebPageBase.ExecutePageHierarchy()
ved System.Web.Mvc.WebViewPage.ExecutePageHierarchy()
ved System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage)
ved ASP._Page_Views_Partials_grid_editors_base_cshtml.Execute() i c:\Development\cabana.koda_sitegen\cabana.koda_sitegen\Views\Partials\Grid\Editors\Base.cshtml:linje 20
Login to the admin area and regenerate the models in the developer section - I believe the error is "telling" you that you have made some changes to document types which will be in the database but haven't been compiled into a dll file on BOTH machines.
This is an older post but just wondered if you'd ever found a solution to this?
I have something fairly similar just now where I'm trying to use a doc type with two columns and then render a macro partial in each column but getting this error, except mines is with
Umbraco.Web.Models.PartialViewMacroModel
Umbraco v7.10.5 and seeing the error on my local environment.
Umbraco Solution
Hi Thomas
Cheers
Nigel
Hey Nigel.
I have tried that. I tried to delete them and regenerate them again, but still gets the same error...
OK - that was a bad guess then huh :-)
Another thought - is your code managed via Source Control ? How have you copied the code between machines ?
If you have used a repo, then are there some files which aren't included in the solution and therefore have been omitted from a build process ?
Yeah I'm using a Source Control. But as I can see, it looks like all the files are on my machine.
But will check when I come back to my work computer :)
H Thomas,
Thanks Stuart
