  • swathi 3 posts 94 karma points
    Jul 19, 2018 @ 09:34
    swathi
    Surface controller model binding
    Thanks in advance for your help.
    I am using Umbraco 7.11.1, I created custom controller in visual studio, Which inherits SurfaceController. And inherits UmbracoViewPage in view.
    Here is the sample code,
    Model:
     public class CompanyModel {...}
    View:
        @inherits UmbracoViewPage<Business.CompanyModel>
    @using (Html.BeginForm("Company", "CoverSurface", FormMethod.Post, new { @role = "form",  @novalidate = "novalidate" }))  ...
    Controller:
     public class CoverSurfaceController : SurfaceController    {
    public ActionResult Company()
               var model = new CompanyModel()
                        //call to generate model
                    return View(model);
    When i run in debug, Routing happens fine and I can see the control hitting right action and view. And the end of view debug, its throwing exception as follows :
    Cannot bind source type Business.CompanyModel to model type Umbraco.Web.Models.RenderModel.
    Exception Details: Umbraco.Web.Mvc.ModelBindingException: Cannot bind source type Business.CompanyModel to model type Umbraco.Web.Models.RenderModel.
    [ModelBindingException: Cannot bind source type Business.CompanyModel to model type Umbraco.Web.Models.RenderModel.]
       Umbraco.Web.Mvc.RenderModelBinder.ThrowModelBindingException(Boolean sourceContent, Boolean modelContent, Type sourceType, Type modelType) +424
       Umbraco.Web.Mvc.RenderModelBinder.BindModel(Object source, Type modelType, CultureInfo culture) +502
       Umbraco.Web.Mvc.UmbracoViewPage`1.SetViewData(ViewDataDictionary viewData) +180
       System.Web.Mvc.WebViewPage.ConfigurePage(WebPageBase parentPage) +57
       System.Web.WebPages.<>c__DisplayClass3.<RenderPageCore>b__2(TextWriter writer) +218
       System.Web.WebPages.HelperResult.WriteTo(TextWriter writer) +10
       System.Web.WebPages.WebPageBase.Write(HelperResult result) +80
       System.Web.WebPages.WebPageBase.RenderSurrounding(String partialViewName, Action`1 body) +63
       System.Web.WebPages.WebPageBase.PopContext() +237
       System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) +98
       System.Web.Mvc.RazorView.RenderView(ViewContext viewContext, TextWriter writer, Object instance) +235
       System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext viewContext, TextWriter writer) +107
       Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer) +113
       System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context) +290
       System.Web.Mvc.ControllerActionInvoker.InvokeActionResult(ControllerContext controllerContext, ActionResult actionResult) +13
       System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +56
       System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +420
       System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult) +52
       System.Web.Mvc.Async.<>c__DisplayClass2b.<BeginInvokeAction>b__1c() +173
       System.Web.Mvc.Async.<>c__DisplayClass21.<BeginInvokeAction>b__1e(IAsyncResult asyncResult) +100
       System.Web.Mvc.Async.WrappedAsyncResult`1.CallEndDelegate(IAsyncResult asyncResult) +10
       System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49
       System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) +27
       System.Web.Mvc.Controller.<BeginExecuteCore>b__1d(IAsyncResult asyncResult, ExecuteCoreState innerState) +13
       System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +29
       System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) +36
       System.Web.Mvc.Controller.<BeginExecute>b__15(IAsyncResult asyncResult, Controller controller) +12
       System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +22
       System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult) +26
       System.Web.Mvc.Controller.System.Web.Mvc.Async.IAsyncController.EndExecute(IAsyncResult asyncResult) +10
       System.Web.Mvc.MvcHandler.<BeginProcessRequest>b__5(IAsyncResult asyncResult, ProcessRequestState innerState) +21
       System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +28
       System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.EndProcessRequest(IAsyncResult result) +9
       System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +9987157
       System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Jul 19, 2018 @ 09:47
    Nik
    Hi Swathi,
    The issue you are seeing is caused by your view code.
    You are inheriting twice, if you remove the first inherits line it should solve the issue for you.
    Nik :-)
    Jul 19, 2018 @ 09:57
    swathi
    Hi Nik,
    Thank you so much for reply.
    As you mentioned I removed the first inherits, still getting the same exception.
    Is there anything else i am missing?
    Thanks, Swathi.
    Jul 19, 2018 @ 10:02
    Nik
    Hmm, does your view have anything like :
    Layout = "Some other view"
    If so, that could be causing it. Surface controllers are usually for returning partial views rather than full views so your controller should do
    Return PartialView() //I can't recall the exact syntax here sorry
    instead of
    Return View()
    You also shouldn't need to be setting a Layout in the partial :-)
    Nik
    Jul 19, 2018 @ 10:07
    swathi
    Thank you so much Nik, Working fine now.I wasn't setting layout but was returning View(). Changing it to partial view fixed it.
    Thanks, Swathi.
