  • Fuji Kusaka 2203 posts 4220 karma points
    Jul 23, 2018 @ 13:21
    Fuji Kusaka
    Dictionary section does not show in backoffice
    Hi Guys,
    For some reasons after installing v7.11. ( not NuGet Installed ) , the Dictionary Section under Settings is not showing up.
    Had a look at the trees.config file and all seems good.
    Jul 23, 2018 @ 13:40
    Dave Woestenborghs
    Hi Fuji,
    In 7.11 the dictionary section is now in Angular instead of the old webforms implementation.
    It's possible that your trees.config is not updated correctly to the new configuration.
    The entry should look like this :
    <add application="settings" alias="dictionary" title="Dictionary" type="Umbraco.Web.Trees.DictionaryTreeController, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="6" />
    Dave
    Jul 23, 2018 @ 14:02
    Fuji Kusaka
    Hi Dave,
    Yes just found out that during the install this didnt get updated.
    from
      <add application="settings" alias="dictionary" title="Dictionary" type="Umbraco.Web.Trees.SettingsDictionaryTreeController, umbraco" iconClosed="icon-folder" iconOpen="icon-folder" sortOrder="6" />
    to
    Jul 23, 2018 @ 14:05
    Dave Woestenborghs
    Hi Fuji,
    The first line is from 7.11 and the second line is from 7.11.1 wich fixed some issues with the new dictionary tree
    Dave
