For clearing cache, we have used the below two lines of code...
When we call the clear-cache page, My server CPU utilization is going to 100% and automatically website is getting down.
Can anyone help me what is the wrong in my code, please?
Hi Suman,
I think this is pretty normal. When calling HttpRuntime.Close(); you actually tell your web application to shutdown.
See : https://docs.microsoft.com/en-us/dotnet/api/system.web.httpruntime.close?view=netframework-4.7.1#SystemWebHttpRuntime_Close
Why are you calling this ?
Dave
Hi Dave, Thank you for your reply.
I thought it will clear the cache for the current request.
I think removing this one will solve your issue.
Thank You Dave. I will try this and monitor the CPU Utilization.
Is that the only code on the entire clear cache page? If not, would you post more?
@Greg,
full code for clear cache...
@ string prefix = null; if (prefix == null) { prefix = ""; } prefix = prefix.ToLower(); List
System.Collections.IDictionaryEnumerator enumerator = HttpContext.Current.Cache.GetEnumerator(); while (enumerator.MoveNext()) { if (enumerator.Key.ToString().ToLower().StartsWith(prefix)) { itemsToRemove.Add(enumerator.Key.ToString()); } } foreach (string itemToRemove in itemsToRemove) { HttpContext.Current.Cache.Remove(itemToRemove); } HttpContext.Current.Cache.Remove("somestring"); HttpRuntime.Close();
Umbraco Cache Problem (Server CPU Utilisation going to 100%)
Hi Suman,
HttpRuntime.Close();you actually tell your web application to shutdown.See : https://docs.microsoft.com/en-us/dotnet/api/system.web.httpruntime.close?view=netframework-4.7.1#SystemWebHttpRuntime_Close
Dave
Dave
@Greg,
