I had previously Url Tracker installed (as a package) but currently have no dashboard any more and the Url Tracker is not any more on the list of my installed packages but it still works.
When I rename a content it writes an entry in the database in icUrlTracker table. However when I go to the old url it shows 404 page instead of redirecting to the new one.
I also have Redirect URl Management and renaming a content does not write an entry in umbracoRedirectUrl table.
So basically Url tracker writes entries but not redirecting the old content.
But Redirect URL Management does not work at all while I want this one to work and get rid of Url Tracker.
I'm not sure why Redirect URL Management is not working, can it be any conflict with Url Tracker?
What are files of Url Tracker I should look for and remove and how to check Redirect URL Management is installed correctly?
That's the case - I checked and had no InfoCaster dlls in my bin folder - in this branch at least. But checked Master branch and removed the dlls from its bin folder. Not sure why the current branch was not working of the dlls were not present but were present in the Master branch only.
Redirect URL Management not working
I have version 7.6 of umbraco.
I'm not sure why Redirect URL Management is not working, can it be any conflict with Url Tracker? What are files of Url Tracker I should look for and remove and how to check Redirect URL Management is installed correctly?
Hi manila
Have a look in your /bin folder
it sounds like you still have the UrlTracker dll present there (if changes are still being tracked to the database table)
The presence of the dll 'turns off' the Redirect Url Management dashboard.
So if you remove the dll called InfoCaster.Umbraco.UrlTracker.dll from the bin folder - that should work again for you.
regards
marc
Gotta follow-up , I'm getting the "classic" 404 from any of the old redirects on an inherited site..
I've checked the configs.. I checked the packages and manifest
no infocaster , SEOchecker, Terratype etc dlls ..
i get a lot of
Status code is 404 yet TrySkipIisCustomErrors is false - IIS will take over. So any ideas will help..
Anyway it worked, thanks Marc
Redirect URL Management is not work in mine, how did you fixed it
