How can I edit this footer notice ??(see the pic below) It's not in the "footer" register card. There you can create footer links and footer content.
And if it's in the template how do I get there?
You should be able to change your footer in your master template page.
On my umbraco site this is normally located on my master template page near the bottom.
How to edit a footer notice ??
How can I edit this footer notice ??(see the pic below) It's not in the "footer" register card. There you can create footer links and footer content. And if it's in the template how do I get there?
Thanks for your help!
You should be able to change your footer in your master template page. On my umbraco site this is normally located on my master template page near the bottom.
e.g. my master page location:![enter image description here](/media/upload/cec3ddee-b5fc-4cd3-bbc7-eed5ee36b140/2018-08-30%2015_13_56-Window.png)
The code for my footer:
Any luck?
Any luck?
