  • sheetal 5 posts 75 karma points
    Oct 05, 2018 @ 08:24
    sheetal
    How to Manage multiple website files and DB with same functionality.
    Hi I need to create multiple websites having same functionality (different name , logo etc. ) with different database server using single instance umbraco package.
    Please suggest me if there is any solution related to this.
  • Harry Spyrou 212 posts 604 karma points
    Oct 05, 2018 @ 10:55
    Harry Spyrou
    Hi sheeetal,
    If I understand correctly you want each website to be in the same Umbraco instance BUT to use different domain databases (e.g. for form submitting)?
    Or do you want the same instance of Umbraco to be looking into a different database to get content?
    Would you mind explaining a bit more?
    Thanks Harry
    Oct 05, 2018 @ 11:53
    sheetal
    Hi Harry Thank you very much for your interest to help me. Let me help you clear my requirement:
    Basically we want to make multi-tenant solution with Umbraco. The end result is a mobile apps per tenant. The end users are having access to mobile app, and currently we are not focusing on the web version of the umbraco for end users.
    The prime concern for performance and data security purpose is the per tenant we must have separate database. There can be one central database to manage the tenant and the document types can be available to the tenants.
    So for that, There will one super admin who can manage multiple tenants or in umbraco's language manage Root nodes for tenant’s content. Each of these tenants will have one admin, who can manage only their respective tenant content only. He should not be able to see other tenant data.
    We want to achieve this using Umbraco only as we are using this system for one tenant and now want to extend for multiple. Suggest me your views and if there is any solution or alternate way to achieve the requirements.
