  • Jay Crowe 42 posts 173 karma points
    Oct 10, 2018 @ 13:43
    Jay Crowe
    Installed Packages installed but not working when deployed
    I have developed the umbraco site on my local machine installed packages etc. When I have deployed the website or pull the code onto another machine the installed packages are there but do not work correctly. I have to uninstall and then install the package again.
    Am I do something wrong? Or do other people experience this issue as well?
    When I have installed the package I have included all of the files into my visual studio solution.
    Regards, Jay
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Oct 10, 2018 @ 14:44
    Nik
    Hi Jay,
    How are you installing the packages?
    If they are installed via Nuget, then I think if you use a publish profile for deployment they should work.
    However, if you are installing them via the Package Manager in the back office, you will probably find that the files in App_Plugins are deploying but the DLL's aren't.
    I would do a comparison of your local Bin folder vs your deployed Bin folder to check DLL's are all present.
    Nik
    Oct 12, 2018 @ 14:10
    Jay Crowe
    Thanks Nik it hadnt included the DLL's.
    Should have known.
    Thanks for your help.
    Jay
