Umbraco Backend issue when setting up Umbraco API with Dependency Injection (AutoFac)
Following the information in Umbraco Documentation
i wrote the following code OnApplicationStarted event to use IoC and AutoFac.
//register all MVC controllers and API controllers in the
//current assembly in the container.
var builder = new ContainerBuilder();
//Register the UmbracoContext as a factory since the below controllers require this in their ctor
builder.Register(c => UmbracoContext.Current).AsSelf();
builder.RegisterInstance(ApplicationContext.Current).AsSelf();
builder.RegisterInstance(new UmbracoHelper(UmbracoContext.Current)).AsSelf();
builder.RegisterControllers(Assembly.GetExecutingAssembly());
builder.RegisterApiControllers(Assembly.GetExecutingAssembly());
builder.RegisterAssemblyTypes(Assembly.GetExecutingAssembly()).AsImplementedInterfaces().InstancePerLifetimeScope();
// register Umbraco MVC + web API controllers used by the admin site
builder.RegisterControllers(typeof(UmbracoApplication).Assembly);
builder.RegisterApiControllers(typeof(UmbracoApplication).Assembly);
// add custom class to the container as Transient instance
RegisterTypes(builder);
var container = builder.Build();
//setup the webapi dependency resolver to use autofac
var resolver = new AutofacWebApiDependencyResolver(container);
GlobalConfiguration.Configuration.DependencyResolver = resolver;
//setup the mvc dependency resolver to user autofac
DependencyResolver.SetResolver(new AutofacDependencyResolver(container));
Unfortunately, i am still getting YSOD errors in backend when i click on CONTENT menu. Also the umbraco menu items on the left side are not loaded and finally when i execute code to add content from code behind the content is not added.
The errors i am getting when i click in Content are the following:
System.AggregateException: One or more errors occurred.
at System.Threading.Tasks.Task1.GetResultCore(Boolean waitCompletionNotification)
at Umbraco.Web.Editors.SectionController.GetSections()
at lambda_method(Closure , Object , Object[] )
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters)
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments)
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary2 arguments, CancellationToken cancellationToken)
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Web.Http.Controllers.ApiControllerActionInvoker.
Inner Exception
I will give a try and reply. I masked it as solution because i haven't done that.
As for Daves suggestion, i have already include the API Controllers registration on my code and still getting the errors.
Hi Thomas, did you come up with a solution for this issue? If so, please let us know your solution. I am getting the same issue, even though doing what Yakov and Dave instructed to do.
Hi, Following the information in Umbraco Documentation i wrote the following code OnApplicationStarted event to use IoC and AutoFac.
1.GetResultCore(Boolean waitCompletionNotification) at Umbraco.Web.Editors.SectionController.GetSections() at lambda_method(Closure , Object , Object[] ) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary2 arguments, CancellationToken cancellationToken) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ApiControllerActionInvoker.Inner Exception
at Umbraco.Web.Trees.ApplicationTreeExtensions.
I think you need register context variables per request to avoid the wrong initialization
In my project, I do autofac init on OnApplicationInitialized event - can you move it to thie event
Hi Thomas,
I think you need to register that api controllers from Umbraco as well
Dave
I will give a try and reply. I masked it as solution because i haven't done that. As for Daves suggestion, i have already include the API Controllers registration on my code and still getting the errors.
Thanks a lot all of you
Cheers, Marcio Barboza
