  • James Inger 11 posts 102 karma points
    Nov 08, 2018 @ 01:09
    James Inger
    Model Builder not working
    HI ALl,
    I created a document type and then generated the Models (dll mode).
    I then altered the locked name of the document and generated the models again.
    Now there is always an error, and cannot create any more document types.
    Error as below for Model Builder
    Failed to build models.
    } expected
    at Umbraco.ModelsBuilder.Building.Compiler.ThrowExceptionFromDiagnostic(String path, String code, Diagnostic diagnostic)
    at Umbraco.ModelsBuilder.Building.Compiler.<>c__DisplayClass12_0.<GetCompilation>b__0(KeyValuePair`2 x)
    at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
    at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
    at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source)
    at Umbraco.ModelsBuilder.Building.Compiler.GetCompilation(StringassemblyName, IDictionary`2 files, SyntaxTree[]& trees)
    at Umbraco.ModelsBuilder.Building.CodeParser.Parse(IDictionary`2 files, IEnumerable`1 references)
    at Umbraco.ModelsBuilder.Umbraco.ModelsBuilderBackOfficeController.GenerateModels(String modelsDirectory, String bin)
    at Umbraco.ModelsBuilder.Umbraco.ModelsBuilderBackOfficeController.BuildModels()
    Any help would be awesome
    What file do I have to edit to fix the problem ??
    Is there anyway to manually generate the Models ???
    Nov 08, 2018 @ 08:59
    Nik
    Hi James,
    This is one of those unhelpful error messages but I think the issue is the version of C# models builder is trying to use.
    If you add this to your App Settings in web.config it might resolve the issue:
    <add key="Umbraco.ModelsBuilder.LanguageVersion" value="CSharp6" />
    Nik
    Nov 08, 2018 @ 21:20
    James Inger
    Thanks for that - But that did not work
    I also have an error as below
    public class _Page_Views_MainPage_cshtml : Umbraco.Web.Mvc.UmbracoTemplatePage<ContentModels.MainPage> {
    Is there a way to fix this manually ??
  • MuirisOG 382 posts 1284 karma points
    Nov 08, 2018 @ 10:07
    MuirisOG
    What new name have you given the document type?
    I believe the underscore character may cause problems.
