  • Magnus Thygesen 8 posts 88 karma points
    Nov 14, 2018 @ 10:36
    Magnus Thygesen
    Dynamic CMS Footer, with own document type
    I need to create a footer with own document type. The person i am creating this site to, should only edit the footer once, and then be applied to all pages.
    My idea was to make a footer document type. Add that document type to a partial view and then i my Master.cshtml file add my partial footer view.
    Something like
    <footer class="section--themed">
        <div class="container">
            <div class="row">
                <div class="col-md-12 ta-center">
                    @Html.Partial("~/Views/Partials/PartialFooter.cshtml")
    </footer>
    However, this doesn't work.
    Any ideas? and feel free to ask for more information.
  • Marc Goodson 2046 posts 13490 karma points MVP 8x c-trib
    Nov 14, 2018 @ 22:32
    Marc Goodson
    Hi Magnus
    The template, and partial view will always be executed in the context of the current page the person is visiting.
    What I can't tell from your example above is how you are getting a reference to your footer content.
    Also I'm not sure if you've created a 'footer' composition and added it to all your document types, or just the Homepage, or whether you've created a specific footer 'document type' and so you have a node in the content tree that contains the 'footer' content.
    So if you have a site with structure
    Home - About Us - News - Contact Us - Etc Settings - Footer
    Then in your master page template, you would need to get a reference to the 'Footer' page, and pass this to the PartialFooter partial view, so this partial always worked with the Footer content.
    eg
                <div class="row">
    //use Xpath based on the alias's of each document type in the tree
    IPublishedContent footerContent = Umbraco.TypedContentSingleAtXPath("/root/settings/footer");
                        @Html.Partial("~/Views/Partials/PartialFooter.cshtml",footerContent )
        </footer>
    Your PartialFooter view should 'expect' an object of IPublishedContent
    @inherits UmbracoTemplatePage<IPublishedContent>
    var apropertyfromfooter = Model.Content.GetPropertyValue<string>("propertyfromFooter");
    <h2>@apropertyfromfooter</h2>
    You could also save this partial executing on every page by using
    @Html.CachedPartial("~/Views/Partials/PartialFooter.cshtml",footerContent,3600)
    to cache the output for 3600 seconds...
    Nov 15, 2018 @ 08:42
    Magnus Thygesen
    My structure is like this at the moment
    • Home
      • News
      • About
      • Footer
    My footer document type contains 2 textboxs with alias locationAddress and cvrNumber.
    My partial view looks like this.
    @inherits UmbracoViewPage<IPublishedContent>
    @using ContentModels = Umbraco.Web.PublishedContentModels;
    <section class="section--themed">
            <div class="row">
                <div class="ta-center col-md-4">
                    <p>info rodekors.dk</p>
                    <P>+45 35 25 92 00</P>
                    <P>@Model.GetPropertyValue("locationAddress")</P>
                    <P>2100 København Ø</P>
                    <P>CVR: 20700211</P>
                    <p>Test</p>
                    <p>
                        Test test
                    </p>
    </section>
    My master view looks like i posted in the start of the thread
            <div class="row">
    </footer>
    And then i also got a template called footer. I am not sure if it is redundent or not. It looks exactly like the partial footer view.
    I hope this clerify how my program looks a bit better. And sorry for how messy it looks, and it is to read. :)
    Marc Goodson, does your solution still works? and do you have any better idea of how to go about it..
    In the end. My footer should contain CMS content and being able to get data from a different database than Umbracos.
    Nov 15, 2018 @ 09:33
    Magnus Thygesen
    Thank you @Marc Goodson! It worked!!
    Nov 16, 2018 @ 23:36
    Marc Goodson
    Glad you got it working Magnus!
