  • smriti 32 posts 103 karma points
    Nov 26, 2018 @ 06:19
    smriti
    Custom Section not loading after upgrade
    I have recently upgraded my Umbraco installation from version 6.0.5 to 6.2.5. Everyhting in new upgrade works fine except the custom sections. The custom sections are visible under sections area but on clicking them, the tree does not appear.
    Below is the code snippet I've used to add custom sections in trees.config file:
    <add silent="false" initialize="true" sortOrder="6" alias="configFiles" application="developer" title="Config Files" iconClosed="folder.gif" iconOpen="folder_o.gif" assembly="Our.Umbraco.Tree.Config" type="LoadConfigFiles" action="" />
      <add silent="false" initialize="true" sortOrder="6" alias="housekeeping" application="developer" title="Housekeeping" iconClosed="folder.gif" iconOpen="folder_o.gif" type="FALMHousekeepingAppTree.loadHousekeeping, FALMHousekeepingAppTree" action="" />
      <add initialize="true" application="doctorfinder" sortOrder="7" alias="doctorfinder" title="Doctor Finder" iconClosed="folder.gif" iconOpen="folder_o.gif" type="LoadCustomSection" action="" />
      <add silent="false" initialize="true" sortOrder="8" alias="contactus" application="contactus" title="Contact Us" iconClosed="folder.gif" iconOpen="folder_o.gif" type="ContactAssembly.Trees.LoadContactSection, ContactAssembly.Trees" action="" />
      <add silent="false" initialize="true" sortOrder="9" alias="HYHData" application="HYHData" title="HYHData" iconClosed="folder.gif" iconOpen="folder_o.gif" type="SiteMapAssembly.LoadCustomSectionXMLSitemap, SiteMapAssembly" action="" />
      <add initialize="true" sortOrder="0" alias="configFiles" application="developer" title="Config Files" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" type="Our.Umbraco.Tree.Config.LoadConfigFiles, Our.Umbraco.Tree.Config" />
    The code for creating trees in custom sections is written in cs files inside app code folder. If anyone has any idea how I can fix this then please help.
    Nov 26, 2018 @ 20:28
    Marc Goodson
    Hi smriti
    Have you got two with the same alias?
    configFiles
    first and last entry, I think for it to work the alias for all the specified trees need to be unique, try manually removing one...
    regards
    Marc
    Nov 27, 2018 @ 04:12
    smriti
    I've removed first entry as it was no longer required but still it did not solve the problem.
  • Biagio Paruolo 1621 posts 1914 karma points c-trib
    Nov 26, 2018 @ 22:13
    Biagio Paruolo
    Are you sure that the icon names are right?
    Nov 27, 2018 @ 04:13
    smriti
    Yes, the icon names are correct. The same code was working fine in version 6.0.5 but after upgrade to 6.2.5 I'm facing this problem.
    Nov 27, 2018 @ 04:14
    smriti
    I'm getting below error in log files:
    2018-11-26 23:10:19,549 [5] WARN umbraco.BusinessLogic.ApplicationTree - [Thread 7] The tree definition: could not be resolved to a .Net object type 2018-11-26 23:10:19,564 [5] WARN umbraco.BusinessLogic.ApplicationTree - [Thread 7] The tree definition: could not be resolved to a .Net object type 2018-11-26 23:10:19,564 [5] WARN umbraco.BusinessLogic.ApplicationTree - [Thread 7] The tree definition: could not be resolved to a .Net object type
    Nov 27, 2018 @ 06:57
    smriti
    Found the solution. Added [Tree("SectionName", "SectionName", "TreeTitle")] before class definition in my .cs file in app_code.
