  • Gaurav Mathur 11 posts 101 karma points
    Nov 28, 2018 @ 16:03
    Gaurav Mathur
    Azure: Template not found and System.Net.Sockets.SocketException
    I have installed Umbraco from Nuget in Visual Studio, its working fine in local. However, when I host it in Azure I got lot of errors.
    Error Type 1:
    System.Exception: No physical template file was found for template Home
    Also,
    System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml and lot more...
    Error Type 2:
    System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
    To fix Error 1 I included all the cshtml in the Views folder to the project. Now I can see them on server, but the error persists.
    For Error 2 I added the TLS1.2 setting, as suggested here. This also didn't fixed the error.
    Below is the log file -
    2018-11-28 13:58:54,208 [P4764/D2/T1] INFO Umbraco.Core.CoreBootManager - Umbraco 7.12.4 application starting on RD0003FF46D6C8 2018-11-28 13:58:54,364 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Determining hash of code files on disk 2018-11-28 13:58:54,395 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Hash determined (took 42ms) 2018-11-28 13:58:54,567 [P4764/D2/T1] INFO Umbraco.Core.MainDom - Acquiring MainDom... 2018-11-28 13:58:54,567 [P4764/D2/T1] INFO Umbraco.Core.MainDom - Acquired MainDom. 2018-11-28 13:58:54,585 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 13:58:55,520 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 937ms) 2018-11-28 13:58:55,520 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IApplicationStartupHandler 2018-11-28 13:58:55,567 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IApplicationStartupHandler (took 45ms) 2018-11-28 13:58:55,629 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 13:58:55,629 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 1ms) 2018-11-28 13:58:55,629 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.PropertyEditors.IPropertyEditorValueConverter 2018-11-28 13:58:55,676 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.PropertyEditors.IPropertyEditorValueConverter (took 53ms) 2018-11-28 13:58:55,676 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 13:58:55,676 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 13:58:55,676 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.PropertyEditors.IPropertyValueConverter 2018-11-28 13:58:55,723 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.PropertyEditors.IPropertyValueConverter (took 45ms) 2018-11-28 13:58:55,756 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 13:58:55,756 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 4ms) 2018-11-28 13:58:55,756 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Web.Mvc.SurfaceController 2018-11-28 13:58:55,801 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Web.Mvc.SurfaceController (took 39ms) 2018-11-28 13:58:55,801 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 13:58:55,801 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 13:58:55,801 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Web.WebApi.UmbracoApiController 2018-11-28 13:58:55,848 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Web.WebApi.UmbracoApiController (took 44ms) 2018-11-28 13:58:59,997 [P4764/D2/T1] INFO Umbraco.Core.DatabaseContext - CanConnect = True 2018-11-28 13:59:00,966 [P4764/D2/T1] INFO Umbraco.Web.Cache.CacheRefresherEventHandler - Initializing Umbraco internal event handlers for cache refreshing 2018-11-28 13:59:01,263 [P4764/D2/T1] INFO Umbraco.Web.Search.ExamineEvents - Initializing Examine and binding to business logic events 2018-11-28 13:59:01,263 [P4764/D2/T1] INFO Umbraco.Web.Search.ExamineEvents - Adding examine event handlers for index providers: 3 2018-11-28 13:59:01,450 [P4764/D2/T1] WARN Umbraco.Core.Sync.DatabaseServerMessenger - No last synced Id found, this generally means this is a new server/install. The server will build its caches and indexes, and then adjust its last synced Id to the latest found in the database and maintain cache updates based on that Id. 2018-11-28 13:59:01,591 [P4764/D2/T1] INFO umbraco.content - Load Xml from file... 2018-11-28 13:59:01,607 [P4764/D2/T1] WARN umbraco.content - Failed to load Xml, file does not exist. 2018-11-28 13:59:01,607 [P4764/D2/T1] INFO umbraco.content - Loading content from database... 2018-11-28 13:59:03,295 [P4764/D2/T1] INFO umbraco.content - Loading content from database... 2018-11-28 13:59:03,514 [P4764/D2/T1] INFO Umbraco.Core.CoreBootManager - Umbraco application startup complete (took 9517ms) 2018-11-28 13:59:03,530 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - Rebuilding index, Provider=InternalMemberIndexer, NodeId=-1 2018-11-28 13:59:03,779 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - PerformIndexAll - Start data queries - member, Provider=InternalMemberIndexer, NodeId=-1 2018-11-28 13:59:04,594 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - PerformIndexAll - End data queries - member, took 810ms, Provider=InternalMemberIndexer, NodeId=-1 2018-11-28 13:59:04,594 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - Rebuilding index, Provider=InternalIndexer, NodeId=-1 2018-11-28 13:59:04,735 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - PerformIndexAll - Start data queries - content, Provider=InternalIndexer, NodeId=-1 2018-11-28 13:59:05,454 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 13:59:05,454 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 13:59:05,471 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.PropertyEditors.IParameterEditor 2018-11-28 13:59:05,517 [P4764/D2/T1] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.PropertyEditors.IParameterEditor (took 46ms) 2018-11-28 13:59:06,173 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - PerformIndexAll - End data queries - content, took 1434ms, Provider=InternalIndexer, NodeId=-1 2018-11-28 13:59:06,173 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - PerformIndexAll - Start data queries - media, Provider=InternalIndexer, NodeId=-1 2018-11-28 13:59:06,814 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - PerformIndexAll - End data queries - media, took 647ms, Provider=InternalIndexer, NodeId=-1 2018-11-28 13:59:06,814 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - Rebuilding index, Provider=ExternalIndexer, NodeId=-1 2018-11-28 13:59:06,892 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - PerformIndexAll - Start data queries - content, Provider=ExternalIndexer, NodeId=-1 2018-11-28 13:59:07,501 [P4764/D2/T11] INFO umbraco.content - Save Xml to file... 2018-11-28 13:59:07,564 [P4764/D2/T11] INFO umbraco.content - Saved Xml to file. 2018-11-28 13:59:07,580 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - PerformIndexAll - End data queries - content, took 691ms, Provider=ExternalIndexer, NodeId=-1 2018-11-28 13:59:07,580 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - PerformIndexAll - Start data queries - media, Provider=ExternalIndexer, NodeId=-1 2018-11-28 13:59:07,799 [P4764/D2/T1] INFO UmbracoExamine.DataServices.UmbracoLogService - PerformIndexAll - End data queries - media, took 210ms, Provider=ExternalIndexer, NodeId=-1 2018-11-28 13:59:08,454 [P4764/D2/T11] INFO Umbraco.Core.Sync.ApplicationUrlHelper - New ApplicationUrl detected: http://umbracoazure20181128085341.azurewebsites.net/umbraco 2018-11-28 13:59:08,454 [P4764/D2/T11] INFO Umbraco.Core.Sync.ApplicationUrlHelper - ApplicationUrl: http://umbracoazure20181128085341.azurewebsites.net/umbraco (UmbracoModule request) 2018-11-28 13:59:16,838 [P4764/D2/T11] WARN Umbraco.Web.Mvc.RenderMvcController - No physical template file was found for template Home 2018-11-28 13:59:16,854 [P4764/D2/T11] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred System.Exception: No physical template file was found for template Home at Umbraco.Web.Mvc.RenderMvcController.CurrentTemplate[T](T model) at Umbraco.Web.Mvc.RenderMvcController.Index(RenderModel model) at lambdamethod(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary2 parameters) at System.Web.Mvc.Async.AsyncControllerActionInvoker.method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary2 parameters) at System.Web.Mvc.Async.AsyncControllerActionInvoker.
    _shutDownMessage=Change Notification for critical directories. bin dir change or directory rename HostingEnvironment initiated shutdown Change Notification for critical directories. bin dir change or directory rename HostingEnvironment caused shutdown
    shutDownStack= at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) at System.Environment.getStackTrace() at System.Web.Hosting.HostingEnvironment.InitiateShutdownInternal() at System.Web.Hosting.HostingEnvironment.InitiateShutdownWithoutDemand() at System.Web.HttpRuntime.ShutdownAppDomain(String stackTrace) at System.Web.HttpRuntime.OnCriticalDirectoryChange(Object sender, FileChangeEvent e) at System.Web.FileChangesMonitor.OnCriticaldirChange(Object sender, FileChangeEvent e) at System.Web.DirectoryMonitor.FireNotifications() at System.Web.Util.WorkItem.CallCallbackWithAssert(WorkItemCallback callback) at System.Web.Util.WorkItem.OnQueueUserWorkItemCompletion(Object state)
    at System.Threading.QueueUserWorkItemCallback.WaitCallbackContext(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() at System.Threading.ThreadPoolWorkQueue.Dispatch() at System.Threading.ThreadPoolWaitCallback.PerformWaitCallback() 2018-11-28 14:08:41,105 [P4764/D3/T23] INFO Umbraco.Core.MainDom - Stopping... 2018-11-28 14:08:41,105 [P4764/D3/T23] INFO Umbraco.Web.ExamineStartup - Examine shutting down 2018-11-28 14:08:41,121 [P4764/D3/T23] INFO Umbraco.Web.ExamineStartup - Complete (took 15ms) 2018-11-28 14:08:41,121 [P4764/D3/T23] INFO Umbraco.Core.MainDom - Released MainDom. 2018-11-28 14:08:41,121 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [Umbraco.Web.Scheduling.IBackgroundTask] Terminating 2018-11-28 14:08:41,121 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [Umbraco.Web.Scheduling.IBackgroundTask] Waiting for tasks to complete 2018-11-28 14:08:41,121 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [Umbraco.Web.Scheduling.IBackgroundTask] Tasks completed, terminated 2018-11-28 14:08:41,121 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [HealthCheckNotifier] Terminating 2018-11-28 14:08:41,121 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [HealthCheckNotifier] Waiting for tasks to complete 2018-11-28 14:08:41,121 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [HealthCheckNotifier] Tasks completed, terminated 2018-11-28 14:08:41,137 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledTasks] Terminating 2018-11-28 14:08:41,137 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledTasks] Waiting for tasks to complete 2018-11-28 14:08:41,137 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledTasks] Tasks completed, terminated 2018-11-28 14:08:41,137 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledPublishing] Terminating 2018-11-28 14:08:41,137 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledPublishing] Waiting for tasks to complete 2018-11-28 14:08:41,137 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledPublishing] Tasks completed, terminated 2018-11-28 14:08:41,137 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [KeepAlive] Terminating 2018-11-28 14:08:41,152 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [KeepAlive] Waiting for tasks to complete 2018-11-28 14:08:41,152 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [KeepAlive] Tasks completed, terminated 2018-11-28 14:08:41,152 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [LogScrubber] Terminating 2018-11-28 14:08:41,152 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [LogScrubber] Waiting for tasks to complete 2018-11-28 14:08:41,152 [P4764/D3/T23] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [LogScrubber] Tasks completed, terminated 2018-11-28 14:08:53,988 [P4764/D4/T29] INFO Umbraco.Core.CoreBootManager - Umbraco 7.12.4 application starting on RD0003FF46D6C8 2018-11-28 14:08:54,048 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Determining hash of code files on disk 2018-11-28 14:08:54,063 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Hash determined (took 14ms) 2018-11-28 14:08:54,173 [P4764/D4/T29] INFO Umbraco.Core.MainDom - Acquiring MainDom... 2018-11-28 14:08:54,173 [P4764/D4/T29] INFO Umbraco.Core.MainDom - Acquired MainDom. 2018-11-28 14:08:54,191 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:08:54,344 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 160ms) 2018-11-28 14:08:54,344 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IApplicationStartupHandler 2018-11-28 14:08:54,344 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IApplicationStartupHandler (took 6ms) 2018-11-28 14:08:54,409 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:08:54,409 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 1ms) 2018-11-28 14:08:54,409 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.PropertyEditors.IPropertyEditorValueConverter 2018-11-28 14:08:54,423 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.PropertyEditors.IPropertyEditorValueConverter (took 0ms) 2018-11-28 14:08:54,423 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:08:54,423 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:08:54,423 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.PropertyEditors.IPropertyValueConverter 2018-11-28 14:08:54,423 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.PropertyEditors.IPropertyValueConverter (took 7ms) 2018-11-28 14:08:54,454 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:08:54,454 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:08:54,454 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Web.Mvc.SurfaceController 2018-11-28 14:08:54,454 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Web.Mvc.SurfaceController (took 0ms) 2018-11-28 14:08:54,454 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:08:54,469 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 2ms) 2018-11-28 14:08:54,469 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Web.WebApi.UmbracoApiController 2018-11-28 14:08:54,469 [P4764/D4/T29] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Web.WebApi.UmbracoApiController (took 6ms) 2018-11-28 14:08:57,766 [P4764/D4/T29] INFO Umbraco.Core.DatabaseContext - CanConnect = True 2018-11-28 14:08:58,423 [P4764/D4/T29] INFO Umbraco.Web.Cache.CacheRefresherEventHandler - Initializing Umbraco internal event handlers for cache refreshing 2018-11-28 14:08:58,798 [P4764/D4/T29] INFO Umbraco.Web.Search.ExamineEvents - Initializing Examine and binding to business logic events 2018-11-28 14:08:58,798 [P4764/D4/T29] INFO Umbraco.Web.Search.ExamineEvents - Adding examine event handlers for index providers: 3 2018-11-28 14:08:59,098 [P4764/D4/T29] INFO Umbraco.Core.CoreBootManager - Umbraco application startup complete (took 5284ms) 2018-11-28 14:09:00,160 [P4764/D4/T19] INFO Umbraco.Core.Sync.ApplicationUrlHelper - New ApplicationUrl detected: http://umbracoazure20181128085341.azurewebsites.net/umbraco 2018-11-28 14:09:00,173 [P4764/D4/T19] INFO Umbraco.Core.Sync.ApplicationUrlHelper - ApplicationUrl: http://umbracoazure20181128085341.azurewebsites.net/umbraco (UmbracoModule request) 2018-11-28 14:09:11,170 [P4764/D3/T24] INFO Umbraco.Core.UmbracoApplicationBase - Application shutdown. Details: BinDirChangeOrDirectoryRename
    _shutDownMessage=Change Notification for critical directories. bin dir change or directory rename HostingEnvironment initiated shutdown HostingEnvironment caused shutdown
    at System.Threading.QueueUserWorkItemCallback.WaitCallbackContext(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() at System.Threading.ThreadPoolWorkQueue.Dispatch() at System.Threading.ThreadPoolWaitCallback.PerformWaitCallback() 2018-11-28 14:21:28,019 [P4764/D4/T5] INFO Umbraco.Core.Logging.OwinLogger - Event Id: 0, state: User logged will be logged out due to timeout: gaurav.s.mathur@avanade.com, IP Address: 96.237.248.210 2018-11-28 14:22:32,026 [P4764/D4/T18] INFO Umbraco.Core.Security.BackOfficeSignInManager - Event Id: 0, state: Login attempt succeeded for username gaurav.s.mathur@avanade.com from IP address 96.237.248.210 2018-11-28 14:22:32,026 [P4764/D4/T18] INFO Umbraco.Core.Security.BackOfficeSignInManager - Event Id: 0, state: User: gaurav.s.mathur@avanade.com logged in from IP address 96.237.248.210 2018-11-28 14:22:35,509 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:22:35,509 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:22:35,509 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving [umbraco.businesslogic.ApplicationAttribute]umbraco.interfaces.IApplication 2018-11-28 14:22:35,556 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved [umbraco.businesslogic.ApplicationAttribute]umbraco.interfaces.IApplication (took 41ms) 2018-11-28 14:22:35,637 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:22:35,637 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:22:35,637 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController 2018-11-28 14:22:35,637 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController (took 0ms) 2018-11-28 14:22:35,650 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:22:35,650 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:22:35,650 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving [umbraco.businesslogic.TreeAttribute]umbraco.interfaces.ITree 2018-11-28 14:22:35,650 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved [umbraco.businesslogic.TreeAttribute]umbraco.interfaces.ITree (took 0ms) 2018-11-28 14:22:49,487 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:22:49,501 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 1ms) 2018-11-28 14:22:49,501 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolving [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController 2018-11-28 14:22:49,501 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolved [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController (took 0ms) 2018-11-28 14:22:50,376 [P4764/D4/T5] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:22:50,376 [P4764/D4/T5] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:22:50,376 [P4764/D4/T5] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.PropertyEditors.IParameterEditor 2018-11-28 14:22:50,376 [P4764/D4/T5] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.PropertyEditors.IParameterEditor (took 8ms) 2018-11-28 14:22:53,522 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:22:53,522 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:22:53,522 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.ICacheRefresher 2018-11-28 14:22:53,522 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.ICacheRefresher (took 0ms) 2018-11-28 14:22:53,569 [P4764/D4/T9] INFO umbraco.content - Load Xml from file... 2018-11-28 14:22:53,584 [P4764/D4/T9] INFO umbraco.content - Loaded Xml from file. 2018-11-28 14:22:57,234 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:22:57,252 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 1ms) 2018-11-28 14:22:57,252 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving [Umbraco.Core.Persistence.Mappers.MapperForAttribute]Umbraco.Core.Persistence.Mappers.BaseMapper 2018-11-28 14:22:57,252 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved [Umbraco.Core.Persistence.Mappers.MapperForAttribute]Umbraco.Core.Persistence.Mappers.BaseMapper (took 2ms) 2018-11-28 14:22:58,203 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:22:58,203 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:22:58,219 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IAction 2018-11-28 14:22:58,219 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IAction (took 1ms) 2018-11-28 14:22:58,656 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:22:58,656 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:22:58,687 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.PropertyEditors.IParameterEditor 2018-11-28 14:22:58,687 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.PropertyEditors.IParameterEditor (took 0ms) 2018-11-28 14:22:58,971 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:22:58,984 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 11ms) 2018-11-28 14:22:58,984 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolving umbraco.cms.businesslogic.macro.IMacroEngine 2018-11-28 14:22:58,984 [P4764/D4/T11] INFO Umbraco.Core.PluginManager - Resolved umbraco.cms.businesslogic.macro.IMacroEngine (took 4ms) 2018-11-28 14:22:59,016 [P4764/D4/T11] WARN umbraco.macro - Error loading partial view macro (View: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 14:22:59,016 [P4764/D4/T11] WARN umbraco.macro - Error loading Partial View (file: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 14:22:59,031 [P4764/D4/T11] ERROR Umbraco.Web.Editors.MacroController - Unhandled controller exception occurred System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId)
    at Umbraco.Web.UmbracoComponentRenderer.RenderMacro(macro m, IDictionary2 parameters, page umbracoPage) at Umbraco.Web.Editors.MacroController.GetMacroResultAsHtml(String macroAlias, Int32 pageId, IDictionary2 macroParams) at Umbraco.Web.Editors.MacroController.GetMacroResultAsHtmlForEditor(MacroParameterModel model) at lambdamethod(Closure , Object , Object[] ) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>cDisplayClass10.9(Object instance, Object[] methodParameters) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary2 arguments, CancellationToken cancellationToken) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__0.MoveNext() 2018-11-28 14:23:00,536 [P4764/D4/T11] WARN Umbraco.Web.Mvc.RenderMvcController - No physical template file was found for template Home 2018-11-28 14:23:00,553 [P4764/D4/T11] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred System.Exception: No physical template file was found for template Home at Umbraco.Web.Mvc.RenderMvcController.CurrentTemplate[T](T model) at Umbraco.Web.Mvc.RenderMvcController.Index(RenderModel model) at lambda_method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary2 parameters) at System.Web.Mvc.Async.AsyncControllerActionInvoker.<BeginInvokeSynchronousActionMethod>b__39(IAsyncResult asyncResult, ActionInvocation innerInvokeState) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResult2.CallEndDelegate(IAsyncResult asyncResult) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResultBase1.End() at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethod(IAsyncResult asyncResult) at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.<InvokeActionMethodFilterAsynchronouslyRecursive>b__3d() at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.<>c__DisplayClass46.<InvokeActionMethodFilterAsynchronouslyRecursive>b__3f() at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.<>c__DisplayClass46.<InvokeActionMethodFilterAsynchronouslyRecursive>b__3f() at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.<>c__DisplayClass46.<InvokeActionMethodFilterAsynchronouslyRecursive>b__3f() at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass33.<BeginInvokeActionMethodWithFilters>b__32(IAsyncResult asyncResult) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResult1.CallEndDelegate(IAsyncResult asyncResult) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResultBase1.End() at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethodWithFilters(IAsyncResult asyncResult) at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass21.<>c__DisplayClass2b.<BeginInvokeAction>b__1c() at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass21.<BeginInvokeAction>b__1e(IAsyncResult asyncResult) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResult1.CallEndDelegate(IAsyncResult asyncResult) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResultBase1.End() at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) at System.Web.Mvc.Controller.<BeginExecuteCore>b__1d(IAsyncResult asyncResult, ExecuteCoreState innerState) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncVoid1.CallEndDelegate(IAsyncResult asyncResult) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResultBase1.End() at System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) at System.Web.Mvc.Controller.<BeginExecute>b__15(IAsyncResult asyncResult, Controller controller) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncVoid1.CallEndDelegate(IAsyncResult asyncResult) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResultBase1.End() at System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult)
    at System.Web.Mvc.Controller.System.Web.Mvc.Async.IAsyncController.EndExecute(IAsyncResult asyncResult) at System.Web.Mvc.MvcHandler.<BeginProcessRequest>b__5(IAsyncResult asyncResult, ProcessRequestState innerState) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncVoid
    1.CallEndDelegate(IAsyncResult asyncResult) at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResultBase1.End() at System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) at System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.EndProcessRequest(IAsyncResult result) at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)
    at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) 2018-11-28 14:23:10,490 [P4764/D4/T9] WARN Umbraco.Web.Mvc.RenderMvcController - No physical template file was found for template Home 2018-11-28 14:23:10,490 [P4764/D4/T9] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred System.Exception: No physical template file was found for template Home at Umbraco.Web.Mvc.RenderMvcController.CurrentTemplate[T](T model) at Umbraco.Web.Mvc.RenderMvcController.Index(RenderModel model) at lambda_method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary
    at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) 2018-11-28 14:23:26,823 [P4764/D4/T26] ERROR Umbraco.Web.Scheduling.KeepAlive - Failed (at "http://umbracoazure20181128085341.azurewebsites.net/umbraco"). System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.EndReceive(IAsyncResult asyncResult) at System.Net.Sockets.NetworkStream.EndRead(IAsyncResult asyncResult)
    --- End of inner exception stack trace --- at System.Net.TlsStream.EndWrite(IAsyncResult asyncResult) at System.Net.PooledStream.EndWrite(IAsyncResult asyncResult) at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
    at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsyncResult ar) --- End of inner exception stack trace --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Umbraco.Web.Scheduling.KeepAlive.<PerformRunAsync>d__5.MoveNext() 2018-11-28 14:23:26,854 [P4764/D4/T9] INFO umbraco.BusinessLogic.Log - Log scrubbed. Removed all items older than 2018-11-27 14:23:26 2018-11-28 14:23:37,978 [P4764/D4/T11] WARN Umbraco.Web.Mvc.RenderMvcController - No physical template file was found for template Home 2018-11-28 14:23:37,978 [P4764/D4/T11] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred System.Exception: No physical template file was found for template Home at Umbraco.Web.Mvc.RenderMvcController.CurrentTemplate[T](T model) at Umbraco.Web.Mvc.RenderMvcController.Index(RenderModel model) at lambda_method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary
    at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) 2018-11-28 14:23:42,530 [P4764/D4/T20] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:23:42,530 [P4764/D4/T20] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:23:42,530 [P4764/D4/T20] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.ITree 2018-11-28 14:23:42,547 [P4764/D4/T20] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.ITree (took 8ms) 2018-11-28 14:23:43,420 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:23:43,420 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:23:43,420 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.Deploy.IServiceConnector 2018-11-28 14:23:43,420 [P4764/D4/T9] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.Deploy.IServiceConnector (took 1ms) 2018-11-28 14:23:44,030 [P4764/D4/T11] WARN umbraco.macro - Error loading partial view macro (View: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 14:23:44,030 [P4764/D4/T11] WARN umbraco.macro - Error loading Partial View (file: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 14:23:44,047 [P4764/D4/T11] ERROR Umbraco.Web.Editors.MacroController - Unhandled controller exception occurred System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId)
    2 parameters, page umbracoPage) at Umbraco.Web.Editors.MacroController.GetMacroResultAsHtml(String macroAlias, Int32 pageId, IDictionary2 macroParams) at Umbraco.Web.Editors.MacroController.GetMacroResultAsHtmlForEditor(MacroParameterModel model) at lambda_method(Closure , Object , Object[] ) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary2 arguments, CancellationToken cancellationToken) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ApiControllerActionInvoker.
    _shutDownMessage=Change Notification for critical directories. bin dir change or directory rename HostingEnvironment initiated shutdown Change in D:\local\Temporary ASP.NET Files\root\76bfd0e3\9088abc9\hash\hash.web HostingEnvironment caused shutdown
    at System.Threading.QueueUserWorkItemCallback.WaitCallbackContext(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() at System.Threading.ThreadPoolWorkQueue.Dispatch() at System.Threading.ThreadPoolWaitCallback.PerformWaitCallback() 2018-11-28 14:42:43,699 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:42:43,699 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:42:43,699 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.Deploy.IServiceConnector 2018-11-28 14:42:43,761 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.Deploy.IServiceConnector (took 66ms) 2018-11-28 14:42:44,652 [P3732/D3/T7] INFO umbraco.content - Load Xml from file... 2018-11-28 14:42:44,667 [P3732/D3/T7] INFO umbraco.content - Loaded Xml from file. 2018-11-28 14:42:54,574 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:42:54,574 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 1ms) 2018-11-28 14:42:54,574 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolving [Umbraco.Core.Persistence.Mappers.MapperForAttribute]Umbraco.Core.Persistence.Mappers.BaseMapper 2018-11-28 14:42:54,621 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolved [Umbraco.Core.Persistence.Mappers.MapperForAttribute]Umbraco.Core.Persistence.Mappers.BaseMapper (took 51ms) 2018-11-28 14:42:55,158 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:42:55,158 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:42:55,158 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.PropertyEditors.IParameterEditor 2018-11-28 14:42:55,158 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.PropertyEditors.IParameterEditor (took 0ms) 2018-11-28 14:42:55,222 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:42:55,222 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:42:55,222 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolving umbraco.cms.businesslogic.macro.IMacroEngine 2018-11-28 14:42:55,283 [P3732/D3/T7] INFO Umbraco.Core.PluginManager - Resolved umbraco.cms.businesslogic.macro.IMacroEngine (took 54ms) 2018-11-28 14:42:55,299 [P3732/D3/T7] WARN umbraco.macro - Error loading partial view macro (View: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 14:42:55,299 [P3732/D3/T7] WARN umbraco.macro - Error loading Partial View (file: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 14:43:09,978 [P3732/D3/T16] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:43:09,978 [P3732/D3/T16] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:43:09,978 [P3732/D3/T16] INFO Umbraco.Core.PluginManager - Resolving [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController 2018-11-28 14:43:10,040 [P3732/D3/T16] INFO Umbraco.Core.PluginManager - Resolved [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController (took 53ms) 2018-11-28 14:43:10,292 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:43:10,292 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 1ms) 2018-11-28 14:43:10,292 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IAction 2018-11-28 14:43:10,321 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IAction (took 35ms) 2018-11-28 14:43:11,417 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:43:11,417 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 1ms) 2018-11-28 14:43:11,417 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.ITree 2018-11-28 14:43:11,496 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.ITree (took 76ms) 2018-11-28 14:43:11,527 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:43:11,527 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:43:11,527 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolving [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController 2018-11-28 14:43:11,527 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolved [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController (took 0ms) 2018-11-28 14:43:11,546 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:43:11,546 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:43:11,546 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolving [umbraco.businesslogic.TreeAttribute]umbraco.interfaces.ITree 2018-11-28 14:43:11,589 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolved [umbraco.businesslogic.TreeAttribute]umbraco.interfaces.ITree (took 53ms) 2018-11-28 14:43:11,623 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:43:11,623 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:43:11,623 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolving [umbraco.businesslogic.ApplicationAttribute]umbraco.interfaces.IApplication 2018-11-28 14:43:11,683 [P3732/D3/T25] INFO Umbraco.Core.PluginManager - Resolved [umbraco.businesslogic.ApplicationAttribute]umbraco.interfaces.IApplication (took 55ms) 2018-11-28 14:43:22,717 [P3732/D3/T22] WARN umbraco.macro - Error loading partial view macro (View: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 14:43:22,717 [P3732/D3/T22] WARN umbraco.macro - Error loading Partial View (file: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 14:43:23,108 [P3732/D3/T22] ERROR Umbraco.Web.Editors.MacroController - Unhandled controller exception occurred System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId)
    at Umbraco.Web.UmbracoComponentRenderer.RenderMacro(macro m, IDictionary2 parameters, page umbracoPage) at Umbraco.Web.Editors.MacroController.GetMacroResultAsHtml(String macroAlias, Int32 pageId, IDictionary2 macroParams) at Umbraco.Web.Editors.MacroController.GetMacroResultAsHtmlForEditor(MacroParameterModel model) at lambdamethod(Closure , Object , Object[] ) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>cDisplayClass10.9(Object instance, Object[] methodParameters) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary2 arguments, CancellationToken cancellationToken) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__0.MoveNext() 2018-11-28 14:43:26,814 [P3732/D3/T16] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 14:43:26,814 [P3732/D3/T16] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 14:43:26,814 [P3732/D3/T16] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.ICacheRefresher 2018-11-28 14:43:27,451 [P3732/D3/T16] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.ICacheRefresher (took 628ms) 2018-11-28 14:43:29,828 [P3732/D3/T16] WARN umbraco.macro - Error loading partial view macro (View: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 14:43:29,828 [P3732/D3/T16] WARN umbraco.macro - Error loading Partial View (file: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 14:43:30,234 [P3732/D3/T16] ERROR Umbraco.Web.Editors.MacroController - Unhandled controller exception occurred System.InvalidOperationException: Could not find the view ~/Views/MacroPartials/latestBlogposts.cshtml, the following locations were searched: ~/Views/MacroPartials/latestBlogposts.cshtml at Umbraco.Web.Mvc.ControllerExtensions.EnsureViewObjectDataOnResult(ControllerBase controller, ViewResultBase result) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId)
    _shutDownMessage=Change Notification for critical directories. bin dir change or directory rename HostingEnvironment initiated shutdown Change Notification for critical directories. bin dir change or directory rename Change Notification for critical directories. bin dir change or directory rename Change in D:\local\Temporary ASP.NET Files\root\76bfd0e3\9088abc9\hash\hash.web HostingEnvironment caused shutdown
    at System.Threading.QueueUserWorkItemCallback.WaitCallbackContext(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() at System.Threading.ThreadPoolWorkQueue.Dispatch() at System.Threading.ThreadPoolWaitCallback.PerformWaitCallback() 2018-11-28 15:07:03,778 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:07:03,778 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 5ms) 2018-11-28 15:07:03,778 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.Deploy.IServiceConnector 2018-11-28 15:07:03,824 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.Deploy.IServiceConnector (took 43ms) 2018-11-28 15:07:04,591 [P4144/D3/T15] INFO umbraco.content - Load Xml from file... 2018-11-28 15:07:04,653 [P4144/D3/T15] INFO umbraco.content - Loaded Xml from file. 2018-11-28 15:07:11,872 [P4144/D3/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:07:11,872 [P4144/D3/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 4ms) 2018-11-28 15:07:11,889 [P4144/D3/T9] INFO Umbraco.Core.PluginManager - Resolving [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController 2018-11-28 15:07:15,043 [P4144/D3/T9] INFO Umbraco.Core.PluginManager - Resolved [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController (took 3156ms) 2018-11-28 15:07:16,390 [P4144/D3/T18] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:07:16,390 [P4144/D3/T18] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 15:07:16,390 [P4144/D3/T18] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IAction 2018-11-28 15:07:18,387 [P4144/D3/T18] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IAction (took 2001ms) 2018-11-28 15:07:18,513 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:07:18,513 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 15:07:18,513 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolving [Umbraco.Core.Persistence.Mappers.MapperForAttribute]Umbraco.Core.Persistence.Mappers.BaseMapper 2018-11-28 15:07:18,559 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolved [Umbraco.Core.Persistence.Mappers.MapperForAttribute]Umbraco.Core.Persistence.Mappers.BaseMapper (took 40ms) 2018-11-28 15:07:19,080 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:07:19,080 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 15:07:19,080 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.PropertyEditors.IParameterEditor 2018-11-28 15:07:19,098 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.PropertyEditors.IParameterEditor (took 4ms) 2018-11-28 15:07:19,142 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:07:19,142 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 15:07:19,142 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolving umbraco.cms.businesslogic.macro.IMacroEngine 2018-11-28 15:07:19,189 [P4144/D3/T15] INFO Umbraco.Core.PluginManager - Resolved umbraco.cms.businesslogic.macro.IMacroEngine (took 45ms) 2018-11-28 15:07:21,861 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:07:21,861 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 15:07:21,877 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.ITree 2018-11-28 15:07:23,127 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.ITree (took 1261ms) 2018-11-28 15:07:23,158 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:07:23,158 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 1ms) 2018-11-28 15:07:23,158 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolving [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController 2018-11-28 15:07:23,158 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolved [Umbraco.Web.Trees.TreeAttribute]Umbraco.Web.Trees.TreeController (took 0ms) 2018-11-28 15:07:23,176 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:07:23,176 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 15:07:23,176 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolving [umbraco.businesslogic.TreeAttribute]umbraco.interfaces.ITree 2018-11-28 15:07:23,236 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolved [umbraco.businesslogic.TreeAttribute]umbraco.interfaces.ITree (took 59ms) 2018-11-28 15:07:23,252 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:07:23,267 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 1ms) 2018-11-28 15:07:23,267 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolving [umbraco.businesslogic.ApplicationAttribute]umbraco.interfaces.IApplication 2018-11-28 15:07:23,474 [P4144/D3/T7] INFO Umbraco.Core.PluginManager - Resolved [umbraco.businesslogic.ApplicationAttribute]umbraco.interfaces.IApplication (took 209ms) 2018-11-28 15:07:23,689 [P4144/D3/T15] WARN umbraco.macro - Error loading partial view macro (View: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: The partial view '~/Views/Partials/CategoryLinks.cshtml' was not found or no view engine supports the searched locations. The following locations were searched: ~/Views/Partials/CategoryLinks.cshtml at System.Web.Mvc.HtmlHelper.FindPartialView(ViewContext viewContext, String partialViewName, ViewEngineCollection viewEngineCollection)
    at System.Web.Mvc.HtmlHelper.RenderPartialInternal(String partialViewName, ViewDataDictionary viewData, Object model, TextWriter writer, ViewEngineCollection viewEngineCollection) at System.Web.Mvc.Html.PartialExtensions.Partial(HtmlHelper htmlHelper, String partialViewName, Object model, ViewDataDictionary viewData)
    at System.Web.Mvc.Html.PartialExtensions.Partial(HtmlHelper htmlHelper, String partialViewName, Object model) at ASP.PageViewsMacroPartialslatestBlogpostscshtml.Execute() in d:\home\site\wwwroot\Views\MacroPartials\LatestBlogposts.cshtml:line 44 at System.Web.WebPages.WebPageBase.ExecutePageHierarchy() at System.Web.Mvc.WebViewPage.ExecutePageHierarchy() at System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) at System.Web.Mvc.RazorView.RenderView(ViewContext viewContext, TextWriter writer, Object instance) at System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext viewContext, TextWriter writer) at Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 15:07:23,689 [P4144/D3/T15] WARN umbraco.macro - Error loading Partial View (file: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: The partial view '~/Views/Partials/CategoryLinks.cshtml' was not found or no view engine supports the searched locations. The following locations were searched: ~/Views/Partials/CategoryLinks.cshtml at System.Web.Mvc.HtmlHelper.FindPartialView(ViewContext viewContext, String partialViewName, ViewEngineCollection viewEngineCollection)
    PageViewsMacroPartialslatestBlogpostscshtml.Execute() in d:\home\site\wwwroot\Views\MacroPartials\LatestBlogposts.cshtml:line 44 at System.Web.WebPages.WebPageBase.ExecutePageHierarchy() at System.Web.Mvc.WebViewPage.ExecutePageHierarchy() at System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) at System.Web.Mvc.RazorView.RenderView(ViewContext viewContext, TextWriter writer, Object instance) at System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext viewContext, TextWriter writer) at Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 15:07:28,973 [P4144/D3/T15] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred System.InvalidOperationException: The partial view '~/views/partials/navigation/topNavigation.cshtml' was not found or no view engine supports the searched locations. The following locations were searched: ~/views/partials/navigation/topNavigation.cshtml at System.Web.Mvc.HtmlHelper.FindPartialView(ViewContext viewContext, String partialViewName, ViewEngineCollection viewEngineCollection)
    at System.Web.Mvc.Html.PartialExtensions.Partial(HtmlHelper htmlHelper, String partialViewName) at ASP.PageViewsMastercshtml.Execute() in d:\home\site\wwwroot\Views\Master.cshtml:line 29 at System.Web.WebPages.WebPageBase.ExecutePageHierarchy() at System.Web.Mvc.WebViewPage.ExecutePageHierarchy() at System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) at System.Web.WebPages.WebPageBase.<>cDisplayClass3.2(TextWriter writer) at System.Web.WebPages.HelperResult.WriteTo(TextWriter writer) at System.Web.WebPages.WebPageBase.Write(HelperResult result) at System.Web.WebPages.WebPageBase.RenderSurrounding(String partialViewName, Action1 body) at System.Web.WebPages.WebPageBase.PopContext() at System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) at System.Web.Mvc.RazorView.RenderView(ViewContext viewContext, TextWriter writer, Object instance) at System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext viewContext, TextWriter writer) at Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer) at System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context) at System.Web.Mvc.ControllerActionInvoker.InvokeActionResult(ControllerContext controllerContext, ActionResult actionResult) at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList1 filters, ActionResult actionResult) at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>cDisplayClass21.<>cDisplayClass2b.
    shutDownMessage=Change Notification for critical directories. AppCode dir change or directory rename HostingEnvironment initiated shutdown Change Notification for critical directories. bin dir change or directory rename Change Notification for critical directories. bin dir change or directory rename Change Notification for critical directories. bin dir change or directory rename Change in D:\local\Temporary ASP.NET Files\root\76bfd0e3\9088abc9\hash\hash.web HostingEnvironment caused shutdown
    shutDownStack= at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) at System.Environment.getStackTrace() at System.Web.Hosting.HostingEnvironment.InitiateShutdownInternal() at System.Web.Hosting.HostingEnvironment.InitiateShutdownWithoutDemand() at System.Web.HttpRuntime.ShutdownAppDomain(String stackTrace) at System.Web.HttpRuntime.OnCriticalDirectoryChange(Object sender, FileChangeEvent e) at System.Web.FileChangesMonitor.OnCriticaldirChange(Object sender, FileChangeEvent e) at System.Web.DirectoryMonitor.FireNotifications() at System.Web.Util.WorkItem.CallCallbackWithAssert(WorkItemCallback callback) at System.Web.Util.WorkItem.OnQueueUserWorkItemCompletion(Object state)
    at System.Threading.QueueUserWorkItemCallback.WaitCallbackContext(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() at System.Threading.ThreadPoolWorkQueue.Dispatch() at System.Threading.ThreadPoolWaitCallback.PerformWaitCallback() 2018-11-28 15:21:20,584 [P4144/D4/T13] INFO Umbraco.Core.Logging.OwinLogger - Event Id: 0, state: User logged will be logged out due to timeout: gaurav.s.mathur@avanade.com, IP Address: 96.237.248.210 2018-11-28 15:21:23,303 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:21:23,303 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 15:21:23,303 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.Deploy.IServiceConnector 2018-11-28 15:21:23,349 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.Deploy.IServiceConnector (took 57ms) 2018-11-28 15:21:24,146 [P4144/D4/T9] INFO umbraco.content - Load Xml from file... 2018-11-28 15:21:24,178 [P4144/D4/T9] INFO umbraco.content - Loaded Xml from file. 2018-11-28 15:21:33,928 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:21:33,928 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 15:21:33,928 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolving [Umbraco.Core.Persistence.Mappers.MapperForAttribute]Umbraco.Core.Persistence.Mappers.BaseMapper 2018-11-28 15:21:33,990 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolved [Umbraco.Core.Persistence.Mappers.MapperForAttribute]Umbraco.Core.Persistence.Mappers.BaseMapper (took 48ms) 2018-11-28 15:21:34,532 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:21:34,548 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 4ms) 2018-11-28 15:21:34,548 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolving Umbraco.Core.PropertyEditors.IParameterEditor 2018-11-28 15:21:34,548 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolved Umbraco.Core.PropertyEditors.IParameterEditor (took 0ms) 2018-11-28 15:21:34,595 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.interfaces.IDiscoverable 2018-11-28 15:21:34,595 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.interfaces.IDiscoverable (took 0ms) 2018-11-28 15:21:34,595 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolving umbraco.cms.businesslogic.macro.IMacroEngine 2018-11-28 15:21:34,688 [P4144/D4/T9] INFO Umbraco.Core.PluginManager - Resolved umbraco.cms.businesslogic.macro.IMacroEngine (took 86ms) 2018-11-28 15:21:38,078 [P4144/D4/T9] WARN umbraco.macro - Error loading partial view macro (View: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: The partial view '~/Views/Partials/CategoryLinks.cshtml' was not found or no view engine supports the searched locations. The following locations were searched: ~/Views/Partials/CategoryLinks.cshtml at System.Web.Mvc.HtmlHelper.FindPartialView(ViewContext viewContext, String partialViewName, ViewEngineCollection viewEngineCollection)
    at System.Web.Mvc.Html.PartialExtensions.Partial(HtmlHelper htmlHelper, String partialViewName, Object model) at ASP.PageViewsMacroPartialslatestBlogpostscshtml.Execute() in d:\home\site\wwwroot\Views\MacroPartials\LatestBlogposts.cshtml:line 44 at System.Web.WebPages.WebPageBase.ExecutePageHierarchy() at System.Web.Mvc.WebViewPage.ExecutePageHierarchy() at System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) at System.Web.Mvc.RazorView.RenderView(ViewContext viewContext, TextWriter writer, Object instance) at System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext viewContext, TextWriter writer) at Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 15:21:38,078 [P4144/D4/T9] WARN umbraco.macro - Error loading Partial View (file: ~/Views/MacroPartials/latestBlogposts.cshtml). Exception: System.InvalidOperationException: The partial view '~/Views/Partials/CategoryLinks.cshtml' was not found or no view engine supports the searched locations. The following locations were searched: ~/Views/Partials/CategoryLinks.cshtml at System.Web.Mvc.HtmlHelper.FindPartialView(ViewContext viewContext, String partialViewName, ViewEngineCollection viewEngineCollection)
    PageViewsMacroPartialslatestBlogpostscshtml.Execute() in d:\home\site\wwwroot\Views\MacroPartials\LatestBlogposts.cshtml:line 44 at System.Web.WebPages.WebPageBase.ExecutePageHierarchy() at System.Web.Mvc.WebViewPage.ExecutePageHierarchy() at System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) at System.Web.Mvc.RazorView.RenderView(ViewContext viewContext, TextWriter writer, Object instance) at System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext viewContext, TextWriter writer) at Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer) at Umbraco.Web.Mvc.ControllerExtensions.RenderViewResultAsString(ControllerBase controller, ViewResultBase viewResult) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, IPublishedContent content) at Umbraco.Web.Macros.PartialViewMacroEngine.Execute(MacroModel macro, INode node) at umbraco.macro.LoadPartialViewMacro(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId) 2018-11-28 15:21:41,836 [P4144/D4/T9] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred System.InvalidOperationException: The partial view '~/views/partials/navigation/topNavigation.cshtml' was not found or no view engine supports the searched locations. The following locations were searched: ~/views/partials/navigation/topNavigation.cshtml at System.Web.Mvc.HtmlHelper.FindPartialView(ViewContext viewContext, String partialViewName, ViewEngineCollection viewEngineCollection)
  • Gaurav Mathur 11 posts 101 karma points
    Nov 30, 2018 @ 18:53
    Gaurav Mathur
    I have redone the whole thing again following the tutorial - https://www.eqtr.com/ideas/posts/2018/03/deploying-umbraco-to-azure/
    Same error. Also it says no package installed, whereas I can see on locally (Starter kit)
  • Bjarke Berg 7 posts 130 karma points hq
    Dec 06, 2018 @ 06:24
    Bjarke Berg
    Hi, How are you deploying to Azure?
    If you are using the release stuff from Visual Studio, then please ensure the missing files are included in the project file. When you install a package in Umbraco the files are not added to the visual studio project automatically.
    Dec 07, 2018 @ 17:42
    Gaurav Mathur
    When you say missing files, you mean the Views, Partials and Macro Partials. Then yes I have included them in Visual Studio and I can see them on Azure using KUDU.
    I am missing the following tutorial - https://www.eqtr.com/ideas/posts/2018/03/deploying-umbraco-to-azure/
    Dec 10, 2018 @ 14:37
    Dennis Aaen
    Hi Gaurav.
    I have talked with my developer's colleague here today and here are what they suggest.
    When you set up a site locally, then you will need to take care of transfer the database to Azure.
    What I would suggest that you are trying to is as follows.
    1. Set up a site on Azure with an Azure DB.
    2. Go through the install process of installation Umbraco CMS on Azure
    3. After this go to the backoffice on your new Azure site.
    4. Install the Starter kit from the backoffice.
    Let me know how it goes.
    Best,
    /Dennis
    Dec 10, 2018 @ 14:56
    Gaurav Mathur
    I have setup site locally with database on Azure. So even the local website is getting data from Azure.
    Having said that, my trial period of Umbraco is expiring/expired and I am not able to host even a simple starter kit Umbraco site on Azure.
    Maybe if I have spent a bit more time diagnosing this issue I would have get it up running. But I was in an impression it will work as is with minimal effort.
    If you can please ask your developers to do a fresh installation of Umbraco and deploy it on Azure, they'll definitely see the issue.
    And yes I am following steps from link which your shared. https://www.eqtr.com/ideas/posts/2018/03/deploying-umbraco-to-azure/
    Dec 10, 2018 @ 16:10
    Dennis Aaen
    I will try setting up one solution tomorrow where I follow https://www.eqtr.com/ideas/posts/2018/03/deploying-umbraco-to-azure/ and let you know how it goes,
    /Dennis
    Dec 11, 2018 @ 15:59
    Dennis Aaen
    Hi Gaurav,
    I have not got access yet to set up an Azure test website here. I will update you when I have the possibility to set up everything and go through the guide.
    /Dennis
    Dec 12, 2018 @ 13:28
    Dennis Aaen
    Hi Gaurav,
    Okay, I think I know what is going on here. Since you are using Visual Studio you should make sure that the Models builder is set to Dll mode.
    By default, it sets to PureLive in the web.config. When you have changed this setting then you need to go into the back office in the developer section.
    In there you will see a Models builder dashboard, when you have to change the Models builder to Dll mode then you will need to click the generate models on the dashboard.
    By doing this your models will be in a DLL file which is the preferred set up when you are using Visual Studio and Umbraco CMS
    You can find the Models Builder documentation here https://our.umbraco.com/documentation/reference/templating/modelsbuilder/
    Best,
    /Dennis
