  • sheetal 5 posts 75 karma points
    Dec 17, 2018 @ 11:27
    sheetal
    Umbraco Connection String
    Hi , for some reason I need to change my connection string dynamically from code. I do not want to put the connection value in config file. Suggest me if there is any other solution except config file.
  • Dan Diplo 1554 posts 6205 karma points MVP 6x c-trib
    Dec 17, 2018 @ 12:49
    Dan Diplo
    I've never tried it, but in theory you can use:
    ApplicationContext.Current.DatabaseContext.ConfigureDatabaseConnection(connString)
    to set the database connection.
    I'd imagine you'd need to do this in the Application Startup events (not sure which one - but as early as possible, I'd guess). See below:
    https://our.umbraco.com/Documentation/Reference/Events/Application-Startup
    Again, not sure if it will work, but seems your best bet.
    Dec 17, 2018 @ 12:51
    sheetal
    Thanks Dan, for the reply.
