  • Bo Jacobsen 610 posts 2409 karma points
    Dec 21, 2018 @ 12:57
    Bo Jacobsen
    dateVal.locale is not a function
    Hey all.
    After i upgrade Umbraco CMS from version 7.4.0 to 7.12.4. I found out that every date picker gives this dateVal.locale is not a function error.
    umbraco.services.js where the error is from.
    angular.module('umbraco.services').factory('versionHelper', versionHelper);
    function dateHelper() {
        return {
            convertToServerStringTime: function (momentLocal, serverOffsetMinutes, format) {
                //get the formatted offset time in HH:mm (server time offset is in minutes)
                var formattedOffset = (serverOffsetMinutes > 0 ? '+' : '-') + moment().startOf('day').minutes(Math.abs(serverOffsetMinutes)).format('HH:mm');
                var server = moment.utc(momentLocal).utcOffset(formattedOffset);
                return server.format(format ? format : 'YYYY-MM-DD HH:mm:ss');
            convertToLocalMomentTime: function (strVal, serverOffsetMinutes) {
                //if the string format already denotes that it's in "Roundtrip UTC" format (i.e. "2018-02-07T00:20:38.173Z")
                //otherwise known as https://en.wikipedia.org/wiki/ISO_8601. This is the default format returned from the server
                //since that is the default formatter for newtonsoft.json. When it is in this format, we need to tell moment
                //to load the date as UTC so it's not changed, otherwise load it normally
                var isoFormat;
                if (strVal.indexOf('T') > -1 && strVal.endsWith('Z')) {
                    isoFormat = moment.utc(strVal).format('YYYY-MM-DDTHH:mm:ss') + formattedOffset;
                } else {
                    isoFormat = moment(strVal).format('YYYY-MM-DDTHH:mm:ss') + formattedOffset;
                //create a moment with the iso format which will include the offset with the correct time
                // then convert it to local time
                return moment.parseZone(isoFormat).local();
            getLocalDate: function (date, culture, format) {
                if (date) {
                    var dateVal;
                    var serverOffset = Umbraco.Sys.ServerVariables.application.serverTimeOffset;
                    var localOffset = new Date().getTimezoneOffset();
                    var serverTimeNeedsOffsetting = -serverOffset !== localOffset;
                    if (serverTimeNeedsOffsetting) {
                        dateVal = this.convertToLocalMomentTime(date, serverOffset);
                    } else {
                        dateVal = moment(date, 'YYYY-MM-DD HH:mm:ss');
                    return dateVal.locale(culture).format(format); // <-- THIS LINE
    umbraco.directives.js where the service is called.
    userService.getCurrentUser().then(function (currentUser) {
        scope.node.createDateFormatted = dateHelper.getLocalDate(scope.node.createDate, currentUser.locale, 'LLL'); // <--- THIS LINE
        scope.node.releaseDateYear = scope.node.releaseDate ? ucfirst(dateHelper.getLocalDate(scope.node.releaseDate, currentUser.locale, 'YYYY')) : null;
        scope.node.releaseDateMonth = scope.node.releaseDate ? ucfirst(dateHelper.getLocalDate(scope.node.releaseDate, currentUser.locale, 'MMMM')) : null;
        scope.node.releaseDateDayNumber = scope.node.releaseDate ? ucfirst(dateHelper.getLocalDate(scope.node.releaseDate, currentUser.locale, 'DD')) : null;
        scope.node.releaseDateDay = scope.node.releaseDate ? ucfirst(dateHelper.getLocalDate(scope.node.releaseDate, currentUser.locale, 'dddd')) : null;
        scope.node.releaseDateTime = scope.node.releaseDate ? ucfirst(dateHelper.getLocalDate(scope.node.releaseDate, currentUser.locale, 'HH:mm')) : null;
        scope.node.removeDateYear = scope.node.removeDate ? ucfirst(dateHelper.getLocalDate(scope.node.removeDate, currentUser.locale, 'YYYY')) : null;
        scope.node.removeDateMonth = scope.node.removeDate ? ucfirst(dateHelper.getLocalDate(scope.node.removeDate, currentUser.locale, 'MMMM')) : null;
        scope.node.removeDateDayNumber = scope.node.removeDate ? ucfirst(dateHelper.getLocalDate(scope.node.removeDate, currentUser.locale, 'DD')) : null;
        scope.node.removeDateDay = scope.node.removeDate ? ucfirst(dateHelper.getLocalDate(scope.node.removeDate, currentUser.locale, 'dddd')) : null;
        scope.node.removeDateTime = scope.node.removeDate ? ucfirst(dateHelper.getLocalDate(scope.node.removeDate, currentUser.locale, 'HH:mm')) : null;
    I have tried to replace the the folder umbraco and umbraco_client with a clean 7.12.4 package, with no luck. Am i missing something obvious?
    Dec 21, 2018 @ 13:03
    Bo Jacobsen
    When i read my own message for the 15th time. I think it might be something to do with the created date on a document and not the date picker it self.
