I've encountered the following issues with an upgraded project. Can anyone confirm these?
I've raised tickets for these.
The project was previously v7.12.4.
Editing an existing color picker property inside a nested content item stops working with JS errors. Creating a new nested content item containing the same color picker works as expected.
Clicking through the content tree prompts for unsaved changes every time.
I've locked #2 down to any page/doctype with a MNTP property on it that isn't empty. As soon as the MNTP has items it starts happening.
I have one project with a mixture of the legacy and MNTP2 and the other project has just the MNTP2 datatype in use. It appears to be happening for both,
Managed to repro now, it's when I have existing entries yep. But I had enabled the labels and when I didn't enable the labels before it starts failing.
Will work on a fix, it's because the values are stored a little different when there are / are not labels. Should be a pretty easy fix.
Did you see my reply regarding the unsaved changes? I managed to lock it down to any page with an MNTP or MNTP2 on it that has entries. If the picker is empty the unsaved message isnt triggered.
Alright, color picker first, go into your ~/Umbraco/Js/umbraco.controller.js and find line 11654: // Complex color (value and label)?
Above that you can add:
// Backwards compatibility, the color used to be stored as a hex value only
if($scope.model.value.length === 6) {
$scope.model.value = { value: $scope.model.value, label: $scope.model.value };
This will read the previous non-complex value and modifies it to be the "complex" value we now expect.
As for MNTP, it looks like it might be a little too sensitive to setting it dirty maybe.. when it loads completely it doesn't trigger the notification, when it doesn't (if you click through the nodes fast enough) you will trigger the notification. I am not sure if this is changed behavior, still investigating.
That's the opposite of what i'm seeing, if I click through the tree frantically (ie dont let everything load) its fine. If I wait for everything to load and then click on another tree item, i get the unsaved changes prompt.
Backpeddling the changes to the MNTP seems to have worked though. :-)
Not sure what you mean? We need to fix some unintended behavior, this issue is open (I assume that this is your GitHub user: https://github.com/umbraco/Umbraco-CMS/issues/3997 ) and there's a PR for it that I'm looking at now.
I seemed to recall in the task list for in-progress umbraco versions, items "re-opened" when stuff is done and is found to still have issues, or breaks something else.
If its all to be handled inside this item, np. :-)
Right-o! Can only re-open items if they've not been released yet. Once they're in a release they'll be listed for that specific versions and we make updates to fix any resulting issues! 👍
I could be doing something wrong, but I upgraded from 7.12.4 to 7.13.1 and had an existing color picker with label from 7.12 that seems to no longer be updating the label value. When I print the color picker value to test I see the hex value changing but not the label. Did anyone else notice this in 7.13.1? This is my data type configuration.
So it appears that in 7.13.1 with the new color picker, the value is always updated on save and publish but the label is not updating. I have the values in the picture above and when I pick a different color and save and publish I can see the new value, but the label does not change (unless you save and publish twice while selecting the same color).
7.13 Issues
Hi Martin,
Have you tried changing the version number in the Config/ClientDependency.config?
There maybe JS changes that are been pulled through due the cache ClientDependency creates.
Matt
Yea client dependency version increased, caches cleared, webserver reset.
The issues occur on my dev build and my QA build. Uggh.
Hi, Sorry, I deleted my last post because I thought I had a false positive but I also have the issue 2 on my site which is running 7.13.
I can't replicate issue 1 as I don't have nested content setup on this site though.
O.
When you see #2, can you please try to figure out which datatypes are on the document type of the content item you're moving away from?
As for #1, I'll try to replicate now.
Hi Sebastian
I tried with a color picker that I've set up in 7.12.4 and then upgraded the site to 7.13.0, it's in a nested content property.
Maybe I've done something different but this is what it looks like to me, no JS errors:
And the configuration is like this:
Hi Sebastiaan
This is the error I get if its any help?
TypeError: Cannot create property 'value' on string 'e93f6f'
In the 7.12.4 project were there already entries? Or did you create them new after upgrading?
If I create new items in the nested content it works fine.
If I try and edit an existing item that was there in 7.12.4 it fails.
Awesome Sebastiaan, thanks
Check. I'll have a look at MNTP too!
~/Umbraco/Js/umbraco.controller.jsand find line 11654:// Complex color (value and label)?Above that you can add:
Hi Sebastiaan
Aha that would be this change in MNTP: https://github.com/umbraco/Umbraco-CMS/pull/2899
You could remove those lines (
~/Umbraco/Js/umbraco.controller.jsln. 11883 & 12009) for now.will this issue will be re-opened?
Apologies, my misunderstanding most likely.
I uploaded a screencast here: https://screencast-o-matic.com/watch/cqV3Y13ZYH
Also there's no dirty check on changes
