  • Tom Bruce 122 posts 506 karma points
    Jan 09, 2019 @ 15:46
    Tom Bruce
    Membership and Groups
    Hi everyone, I have created 2 groups within Umbraco backend, group1 and group 2.
    Everything works ok.
    I can assign different members to different groups, but after assigning members from one group to another group.
    Umbraco doesn’t display their icons/names in the correct membership folder.
    They are assigned to the correct group and everything works ok, but visually they are displayed in the wrong folder.
    Any pointers much appreciated.
    Jan 18, 2019 @ 22:37
    Hi Tom
    What version of Umbraco are you using? I suspect this might be a small UI bug that needs to be addressed - Can you perhaps show a screendump of what it looks like? The membership section could use some TLC in general :)
    Looking forward to hearing from you!
    Jan 22, 2019 @ 10:44
    Tom Bruce
    Thanks for replying Jan, details below;
    Umbraco 7.11
    I have created 2 groups, Applicant and Caseworker;
    If I assign Tim to the Casework group;
    Tim is not moved from the Applicant folder. I would of thought Tim would have been moved to the Caseworker folder;
  • Kerri Mallinson 113 posts 497 karma points
    Jan 22, 2019 @ 11:41
    Kerri Mallinson
    Hi Tom,
    The sub folders under members are for member types, not for member groups. If Tim has a member type of 'Applicant' he will always be in that folder regardless of which groups he is added to.
    Kerri
    Jan 22, 2019 @ 11:45
    Tom Bruce
    Thanks Kerri, yep makes sense :)
    Jan 23, 2019 @ 10:45
    Kerri Mallinson
    no problem Tom, If it helped, can you mark the post as the answer to show the topic as solved to help others. Thanks :)
