I've set up a new clean Umbraco Installation (With integrated authentication) if I remember correctly.
Then after some changes tried to change the connectionString in Web.config to point to my new machine etc.
The problem is here. I get this:
and I'm assuming this doesn't let me connect because it's getting its connection settings through source code?
I'm using modelsbuilder API mode (Jon Jones ftw)
Does anyone know where exactly in the source code it is or what do I need to change?
Thanks Harry
No idea what happened, but if I remove the connection string and place it right above the previous connection string (that was commented out) works just fine. Go figure.
Found SQL connection string in source code - v7.13
Thanks Harry
