Hi. I have a problem with uSync, it doesn't delete old type on import all. My sync config is manually sync. I do full export, and move out the data folder just in case. When I create new data type or document type, and I copy back the old data folder and do full import - the new types I added are not delete. My usync version is 4.0.5.0 . should it be this way? any suggestions?
uSync not delete old types
Thank for help!
Hi asaf
I think uSync plays 'safety first', and any 'delete' actions are stored in an additional file:
/uSync/data/uSyncActions.config
(did that file get deployed in your situation?)
and does it contain your deletions?
regards
Marc
No uSyncActions.config file has created in uSync\Data, even if I create new type and delete it. Baside that, everithing work as expected.
Is it related to the one I have installed usync content edition?
I believe you have to turn on the tracking of deletes in the usync backoffice configuration file as well.
