I'm getting this error and I can't figure out what is wrong?
Any ideas?
Hi Leonardo,
These are the valid parameters for the trace element in your web.config. Try changing requestPageSize to requestLimit or removing it.
<trace enabled="true|false" localOnly="true|false" pageOutput="true|false" requestLimit="integer" mostRecent="true|false" writeToDiagnosticsTrace="true|false" traceMode="SortByTime|SortByCategory" />
David
Hi David, thank you for your response. I tried to do as you suggested but now i'm getting the problem here:
Have you inherited this web.config from somewhere?
Try changing requestPageSizes to requestLimits.
<requestFiltering> <requestLimits maxQueryString="52428800"/> </requestFiltering>
Thanks it works now!
Upload image
Unrecognized attribute 'requestPageSize'. Note that attribute names are case-sensitive.
Any ideas?
Hi Leonardo,
David
