  • Advance Ngwarati 25 posts 127 karma points
    Jan 31, 2019 @ 10:59
    Advance Ngwarati
    Model and Controller folders are missing.
    I'm new to umbraco and i have given an umbraco website to modify and add new stuff on it. The problem i'm facing is the folders i have given doesn't contain the model and controller folder. So is it possible in umbraco to have a view folder only?
    Feb 04, 2019 @ 21:53
    Alex Skrypnyk
    Yes, it's possible
    Models and controllers can be compiled to a dll.
    Or they can be in App_Code, or site can work only with views.
    And this is not Umbraco question, it's .net general
    Alex
    Feb 05, 2019 @ 15:28
    Advance Ngwarati
    Thanks Alex,
    Another quick question, I unpublish content from my website and re-publish it, but it seems as if the content will no longer appear on the front-end. I'm so confused and stuck what next can i do. Thanks in advance.
    Feb 05, 2019 @ 16:05
    Alex Skrypnyk
    You are always welcome!
    When you unpublush the content and then do re-publish of all content - content that was unpublished will still be unpublished until you publish it again.
    Feb 05, 2019 @ 17:05
    Advance Ngwarati
    Thanks again Alex
    I re-publish that content again and again but there is no any luck at all. I don't know what else to do, of which that content is on the live website. Any help will be appreciated.
    Feb 05, 2019 @ 21:19
    Alex Skrypnyk
    Can you show the code that renders content that is missing?
