  • Connie DeCinko 95 posts 248 karma points
    Feb 18, 2019 @ 15:38
    Connie DeCinko
    Integrating applications with an Umbraco site
    When someone asks "how do we integrate our stand alone .NET apps with an Umbraco website?" what is a good answer? I typically tell them how we can iFrame the app and other similar methods.
    How do you typically include apps in your site?
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Feb 18, 2019 @ 16:24
    Nik
    Hi Connie,
    From that question my response would probably start with, "Firstly, what do you mean by integrate, and secondly, can we see your existing app"
    Those two questions could help guide you on the type of integration you want to do. In some cases you might iframe it, in others you might create your own front end for it in Umbraco, alternatively you might look to use custom routing so it stays separate but incorporated into the same domain some how.
    So, yeah, it kinda varies depending on use case and app type :-)
    Nik
