  • Emil Lindgren 28 posts 190 karma points
    Feb 28, 2019 @ 13:48
    Emil Lindgren
    Focal Point functionality
    Hello so i have a quest ion about the focal point in Umbraco
    if i move the focal point, shouldn't some typ of cordinates change and be saved? and i shouldn't be needing the image crop? the crop works fine, but not focal pointer, its never updated. so is there something Im missing or is there something that needs to be done?
    I just want the Focal pointer not the cropper.
    Kind regards/ Emil
  • Marius 6 posts 77 karma points
    Feb 28, 2019 @ 15:28
    Marius
    Maybe this post will give you better idea how this functionality works https://our.umbraco.com/forum/using-umbraco-and-getting-started/81438-image-focal-point-question
  • Carlos Mosqueda 244 posts 435 karma points
    Feb 28, 2019 @ 16:14
    Carlos Mosqueda
    @Emil,
    Sometimes when we have had to update a focal point (we use Slimsy which just extends the crop tool), I have had to just republish the page the image was on. But other times I have not, which has been most cases.
    Are you trying to update the image than look at the frontend on the site to see the change? Or are you actually trying to get the coordinates themselves?
